In the latest version of DE there doesn't seem to be any way to make it re-read sectors that timeout (not error out, but timeout). I seem to recall being able to do it in previous versions of DE though.
Anyone know a method to force it to re-read sectors that timeout?
I've got an odd case here of a drive with firmware corruption (which can't be fixed) but that can read a few hundred sectors before getting stuck busy after each soft reset. The problem is, the first sector it tries to read each time stays red and isn't automatically re-read after the soft reset.
How To Re-Read Timeout Sectors
Moderator: Alex_TS
- DataMedics
- d_d_recovery
- New user
Re: How To Re-Read Timeout Sectors
Doesn't the 'attempt' box to the right of the software reset do that?
- DataMedics
You'd think, but it never seems to. I know the sectors aren't bad because on subsequent passes they do clear. It's just annoying that I can't get it to re-read that first sector on the initial pass. So I keep getting about 1000 green, 1 red, 1000 green, 1 red. Then on follow up passes, it get's one red then clears the next two. I'm just trying to avoid having to run 100 passes to clear all these reds.
- d_d_recovery
- New user
Does 'reading with hardware reties' in 'command to read' help?
You need to uncheck 'single sector read' and 'skip sectors on read error' (or similar) I think
- DataMedics
northwind wrote:Source of the post You need to uncheck 'single sector read' and 'skip sectors on read error' (or similar) I think
Yes, I know that and have had those off from the start.
d_d_recovery wrote:Source of the post Does 'reading with hardware reties' in 'command to read' help?
Unfortunately no, it's the same.
For now, I've just queued up a ton of re-read passes to deal with it. But it's just annoying.
