DE Destination drives recommendation setup (ESATA or USB 3.x)?
Posted: 10.02.20, 22:29
Using PC3000+DE 4-port version, I've been using a separate 4-port SATA card + SATA-ESATA cables + ESATA Docking stations for many years.
The ESATA docking toasters I've been using all fail after 1.5-2.5 years and I'm tired of cycling them out. Also, I think they might have an 8TB limit for drive sizes in some cases, so I've been considering changing up my destination 4-port setup.
Do USB 3.x cards work as well as SATA/ESATA PCIE cards for destination drives for speed, stability, detection, etc?
If cloning 4 drives full speed in DE to USB drives, will a standard 4-port USB3.0/3.1 gen 1 card become a bottleneck for data speed transfer in real-world experience? There's a ton of things on paper to consider that may or may not have an effect on the real-world situation of cloning from 4 port PC3k+DE on all 4 ports at the same time. I've read about UASP enabled USB cards using less CPU power, though I'm not sure how much that actually would matter.
I was thinking of trying a USB 3.1 Gen2 10Gbps 4 port card thinking that should more than accommodate transfer speed needs, but perhaps even a 4 port usb 3.0 / 3.1 gen1 card would too? Or, perhaps 2, 2-port USB 3.0 cards would be better...
Anyone (including ACE) have any recommendations?
