Where is the option to copy files off Data Extractor?
Posted: 26.10.19, 01:13
by Teruel
I am not a usual user of Data Extractor for logical recovery...
It has done a partition scan and found a valid NTFS partition on the faulty disk and has shown a folder tree on right-hand-side panel.
But, the last time I used DE, there was little check boxes beside each folder. I could then select folders and use a "copy" command.
However, this time I can see no check boxes beside recovered folders and no option to "copy" these files?
Re: Where is the option to copy files off Data Extractor?
Posted: 28.10.19, 14:10
by d_d_recovery
You need to go back into the main window, open up 'Disk Folder Result' and your check boxes will be there.
