Unable to decrypt drive
jimpan
Postby jimpan » 29.07.19, 15:59
Hi there. Hoping someone can help. I have an SSD drive that is from a MacBook Pro Retina early 2013. I was advised there is no support for the controller which is 88SS9174-BLD2.
However I was able to load it up in DE and can see the APFS volume. It also lists me the Macintosh HD and whenI go to it, it asks for a password. I input the FileVault password that the user has given me and get an error message
that says "There is no any KEK!" and "There is no any VEK!". I do not understand what these error messages are.
I can also see two other options when I right click the APFS volume which Decrypt partition but is greyed out.
Has anyone had any experience with APFS volume that is file vaulted?
Any steps or suggestions would be greatly appreciated.
Jim
d_d_recovery
Re: Unable to decrypt drive
Postby d_d_recovery » 29.07.19, 16:07
What happened to the SSD? Did it fail during a Mac OS update?
ThomasH
Postby ThomasH » 30.07.19, 04:19
I'm having a similar issue now with an APFS hard drive, encrypted, that required headswap and has lots of scattered damage everywhere.
I'm using the latest version of DE released 7-29-19, and I had tried with the older version too, with the same results.
I made sure that I selected to use 512b sectors when starting DE (not physical 4k sectors) or it doesn't start to work.
I get the same KEK VEK errors.
With DE, I can choose to mount the volume to Windows, and then Rstudio can receive the password and unlock the volume. I can get some of the data recovered with Rstudio+DE, but it's far from ideal since I have much less control for mapping, sector skipping, and resets that load PSHT+RDMT from saved files (it's a HGST-ARM).
When I first click on the encrypted sub-partition, DE automatically asks for the password. When I enter it, I get:
Encryption key is not assigned for this volume! Add password to decrypt the data
Failed to check APFS metadata block 5 557, LBA = 454 096
Failed to get catalog object
When I use DE to try to 'Map' just the selected encrypted partition it only sees it as 0 sectors and reports in this in the log:
I can try to 'Map' partitions prior to the 'encrypted subpartition'--I don't know what to properly call this-- in DE, but it doesn't help with decrypting and doesn't take the user's password.
Any suggestions?
d_d_recovery
Postby d_d_recovery » 30.07.19, 17:31
ThomasH wrote:Source of the post I'm having a similar issue now with an APFS hard drive, encrypted, that required headswap and has lots of scattered damage everywhere.
Any suggestions?
Have you tied the new DE version launched a few days ago?
ThomasH
Postby ThomasH » 12.08.19, 22:18
Yes, I'm using the latest version.
FTWOTECHNOLOGY
Postby FTWOTECHNOLOGY » 14.03.21, 11:27
same problem im facing.but data can be extracted with the help of r studio
datasalvage
Postby datasalvage » 07.03.22, 09:17
hi guys :wave: :wave: :wave: :wave: :wave:
same problem here^^ headache and sleepness week lol on pc-3000 i got the same errors.
did someone figured out how to extract the data?
my case is a clone of macbook pro m1 2019 model with latest macos on it.
Return to “Data Extractor”
