DE error opening an existing task
Moderator: Alex_TS
Spark
Postby Spark » 15.07.19, 22:51
I got this error opening an existing task
Error: TTask.Create - Create Drive - dmTask_4.Transaction :Transaction is not active
It doesn't change restart the utility or downgrade to a lower version.
Source drive is a USB WD
What the message mean?
Thank you all
Spark
Re: DE error opening an existing task
Postby Spark » 16.07.19, 12:20
Problem solved.
Moving (not copy) the task to another disk with total commander get "Please remove the write protection!"
On source disk there isn't in explorer the "CUT" option so I just copied it (not moved) to another disk
Now task opens regularly and i'm doing research on the problem related with this unit.
unspoken
Postby unspoken » 27.12.19, 13:16
same problem and had to start image process again. :???: :???:
unspoken
Postby unspoken » 27.12.19, 13:24
Let me tell you the error. image process is over, I saw the folders, I scanned mft+indx process was finished then DE gave error and then the task was not opened again.
Return to “Data Extractor”
