problem with map...map is forcasted
DCDL
Postby DCDL » 12.07.19, 07:33
Could someone please explain what these errors mean? They are only appearing on large video files but all sectors are read ok. The videos dont play all the way through so there is problems with them but all sectors good so Im not sure what is causing the problems.
3 -> File H:\Rescue 780554\Elements\Music\iTunes\Movies\Crank 2_ High Voltage.m4v has been saved, but it have problem with map!
3 -> File saving error H:\Rescue 780554\Elements\Music\iTunes\Movies\Crank 2_ High Voltage.m4v : Map is forecasted!
Thanks in advance,
Lawrence
SGdata
Re: problem with map...map is forcasted
Postby SGdata » 14.07.19, 10:50
I think that there is something messed up with map creation. Generaly, i have many problems with maps in newest version. For example, when map is creating, program likes to freeze, and there is no other option than to kill the process. Other thing is that map info shows that there are unread sectors. But when i create a map of them, the map shows nothing. Also there are sectors marked with pink cross like when sectors can't be read in UDMA, but those sectors are green also. Already showed it to TS but Garry doesn't see any problem...
Postby gameboybin » 13.02.25, 16:44
So i recently came back to my old UDME PC3000 with old DE. Got the same exact problem with a 1.8 inch HDD 40gb for SONY Handicam. Since this havent mentioned after 2019. I guess the problem got resolved in future updates
Return to “Data Extractor”
