Hello All,
I used DE for imaging a drive, and i encounter a bug when i want to call the task . Here is the message " error Ttaskcreate create drive access violation at address 00000000.
I reboot my PC, it doesn't help
Do you have a solution please?
Thanks for your quick reply
Bye for now
BUG Dataextractor
Re: BUG Dataextractor
- Can you tell me what is your DE version and what drive you are working with?
- What reading mode is set up ?
The drive i'm working on is Hts3232A7A364, DE version is 5.2.26. The reading mode is : UDMA 133.
The drive was imaged fully but i closed the task and call back the task i got this message.
Thank You
Thank You
Sometime this error is caused by parrallel task with performed analysis...
Did you open two or more task at the sime time?
