Clearing black blocks from DE project bitmap
odedshankar
Postby odedshankar » 29.07.14, 15:46
Hi Guys,
I have a complex case where i am using smart hot swap and i manage to get access to the data and running an image.
Sometimes the disk is restarting even it is not suppose to as i configured only software reset on error, but when it happens, the drive restart without its native PCB and the in DE i get many black blocks until i stop the image process, re-do the hotswap process and continue imaging, but the black block are not retried for imaging.
My question is how do i clear black blocks from the imaging project bitmap to be able to re-try these black blocks?
also how can i configure the DE not to repower the drive, just software reset?
Please advise,
Cheers
Re: Clearing black blocks from DE project bitmap
Postby AJ2008 » 29.07.14, 15:48
Select "Service -> Clear Map ->" then select the blocks you want to clear and press apply.
Will take several seconds to several minutes depending on the size of your drive.
Nick_TS
Postby Nick_TS » 30.07.14, 19:41
Also you can remove flag "Skip sectors at loss of readiness" in DE parameters when you will rewrite black blocks
odedshankar
Postby odedshankar » 31.07.14, 11:58
thanks guys will try it out
Return to “Data Extractor”
