I guys is it possible to image the data area only of a hard drive with bad sectors using DE?
if its possible can someone point in the right direction
thanks
Image Data Area Only with DE
Re: Image Data Area Only with DE
You need to image $Bitmap.
In Explorer view, right click on the filesystem (i.e NTFS), then select 'Used Sectors from $Bitmap', then image the subsequent chains.
For alternate file systems the option may be slightly different, but should always make reference to used sectors
Thank you for your reply AJ2008 i will try that today
