I am trying to clone the hdd which is connected to ATA1 and the destination device chosen USB HDD. The error message at log
"Writing error on destination drive!
TWriteSysDriveThread.Msg -> Catastrophic failure
Write error on destination drive!
TWriteSysDriveThread.Msg -> Catastrophic failure "
How we can enable direct access to USB hdd in WINDOWS7 environment.
thanks in advance
VENKAT
Re: Writing error on destination drive!
I'm not sure, but why don't you use regular SATA drives for imaging?
I see this error (and similar) in Win7 when using destination disk with valid MBR.
If I use erased disk as destination I never see message.
I assume it is related to windows 7 locking access to partitioned volumes, but Im not sure
Did you enable the "modify MBR" checkbox when picking the destination drive? I believe that will make it so Windows won't try to access the drive.
