Page 1 of 2
Kingston 16 GB microSD HC SDCS
Posted: 12.11.25, 16:59
by MHS-Solutions
Number on SD:
B0664-004.A00LFTS
It is the micro SD Type 44,
so I have the pinout and everything is connected well with the spider board.
I have connected VCC (3,6V-1,8V) and ground at the interface.
https://ibb.co/C5TK71cGhttps://ibb.co/0p4qckppBut it's not possible to read the id of the sdcard,
any idea?
Re: Kingston 16 GB microSD HC SDCS
Posted: 14.11.25, 15:03
by italyassistance
write the id,
Posted: 19.11.25, 10:33
by MHS-Solutions
The problem is that I can't read the id.
Posted: 19.11.25, 14:13
by italyassistance
if id is 0x0000 check pin, sincerly i prefer solder pin, because spider In my opinion it is only suitable for MSDs with very large pads.
Posted: 21.11.25, 12:01
by MHS-Solutions
I will give it a try, thanks!
Posted: 24.11.25, 14:02
by MHS-Solutions
Now the connection problem is solved,
but it's a unrecognized chip:
Any idea about the reading parameters?
I just tried to define them by my own now and now I'm reading the dump.
Posted: 24.11.25, 14:36
by italyassistance
MHS-Solutions wrote:Source of the post Now the connection problem is solved,
u can try set manual, probably id have some caracterc wrong, but if u read good part of chip, id wrong it is not a problem.
Posted: 24.11.25, 17:50
by MHS-Solutions
[24.11.2025 16:46:27]: Microchip ID =00 PATH =01:
[24.11.2025 16:46:28]: Packet Size = 128 pages. Microchip reading...
[24.11.2025 16:46:28]: ------------------------------------------------------------------
[24.11.2025 16:46:28]: Operation parameters
[24.11.2025 16:46:28]: Pin State....................: ID= 8 (TSOP-48)(Default (All are Z))
[24.11.2025 16:46:28]: States by pin..........(PIN):(STATE)
[24.11.2025 16:46:28]: 01: -> Z
[24.11.2025 16:46:28]: 02: -> Z
[24.11.2025 16:46:28]: 03: -> Z
[24.11.2025 16:46:28]: 11: -> Z
[24.11.2025 16:46:28]: 20: -> Z
[24.11.2025 16:46:28]: 21: -> Z
[24.11.2025 16:46:28]: 22: -> Z
[24.11.2025 16:46:28]: 23: -> Z
[24.11.2025 16:46:28]: 24: -> Z
[24.11.2025 16:46:28]: 26: -> Z
[24.11.2025 16:46:28]: 27: -> Z
[24.11.2025 16:46:28]: 28: -> Z
[24.11.2025 16:46:28]: 33: -> Z
[24.11.2025 16:46:28]: 34: -> Z
[24.11.2025 16:46:28]: 35: -> Z
[24.11.2025 16:46:28]: 38: -> Z
[24.11.2025 16:46:28]: 39: -> Z
[24.11.2025 16:46:28]: 40: -> Z
[24.11.2025 16:46:28]: 45: -> Z
[24.11.2025 16:46:28]: 46: -> Z
[24.11.2025 16:46:28]: 47: -> Z
[24.11.2025 16:46:28]: Reading algorithm............: ID= 1: SDR
[24.11.2025 16:46:28]: Reading rule.................: ID= 0
[24.11.2025 16:46:28]: Autoverification.............: NO
[24.11.2025 16:46:28]: Timings.....................:
[24.11.2025 16:46:28]: T1: 62.4 ns
[24.11.2025 16:46:28]: T2: 20.8 ns
[24.11.2025 16:46:28]: tREH: 83.2 ns
[24.11.2025 16:46:28]: tRP: 83.2 ns
[24.11.2025 16:46:28]: Full period: 166.4 ns. Max Speed 4 Mb/s (SDR!)
[24.11.2025 16:46:28]: Attention! Probably you need to use slow Read Mode
[24.11.2025 16:46:28]: (if big part of data is FF)
[24.11.2025 16:46:28]: It's recommended to use next timings: t1=6, t2=2, tREH=8
[24.11.2025 16:46:28]: Back analisys.............: NO
[24.11.2025 16:46:28]: Correct ECC...............: NO
[24.11.2025 16:46:28]: Power Adaptert Parameters (VCC,VCCQ) will be get from chip database
It's reading now, but I'm unsure about page size and block size.
Posted: 25.11.25, 14:16
by italyassistance
when u have update, I will try to help you
Posted: 28.11.25, 09:06
by MHS-Solutions
Thank you very much, I've tried different page sizes and read the dump.
But ECC is not detected and I'm also not able to find a fitting XOR, any advice?
Posted: 28.11.25, 15:00
by italyassistance
which is a pinout? 44 is a model of pc3000 database? which is a flash sofware version? i think that correct id is 0xAD3a1803
Posted: 28.11.25, 19:08
by MHS-Solutions
italyassistance wrote:Source of the post which is a pinout? 44 is a model of pc3000 database? which is a flash sofware version? i think that correct id is 0xAD3a1803
Yes exactly, the type 44 is in the database, I've used the pinout from there and it worked.
I'm using v9.1.7.
I will try the settings from id 0xAD3a1803, thanks!
Posted: 01.12.25, 09:05
by MHS-Solutions
Your hint really helped me, with the settings for the 0xAD3A1803 I was able to read a dump where at least any XOR was found with the analysis.
I've applied ASMedia BLK=384 PG=1843 (1152x16) AF9E02 where most headers were found,
but they are very rare.
Here's a picture:
https://ibb.co/9Hc1pwfjChecked size is also much less than page size as we see.
Further tried transformations did not improve the result as far I've tried (split by block, join ..., rotation, ...).
And also, I still was never able to detect any ECC so far.
Do you have another advice?
Posted: 01.12.25, 14:24
by italyassistance
paste photo of trasformation that u apply, usually this chip found ecc after xor, u try solutions in database? I need to check, if you want we can organize it and I'll connect remotely to take a look.
Posted: 01.12.25, 14:58
by MHS-Solutions
italyassistance wrote:Source of the post paste photo of trasformation that u apply, usually this chip found ecc after xor, u try solutions in database? I need to check, if you want we can organize it and I'll connect remotely to take a look.
https://ibb.co/99qdHC3cNo ECC after XOR
, yes this would be really great if you would do this?
