Is there a solution for read BGA-132 chip's dump out?
youngyj
Postby youngyj » 28.03.16, 08:13
Is the circuit board support the bga 132?
Re: Is there a solution for read BGA-132 chip's dump out?
Postby Roman_TS » 28.03.16, 10:48
You can easily use BGA-152 adapter for BGA-132 chip reading. What's the point to make it so complicated? :) Anyway - if you want - you can use Circuit Board for BGA-132 chip soldering on it :)
youngyj
Postby youngyj » 29.03.16, 11:28
Thanks .
Is the BGA-152(132) adapter compatible with the version 3.0 of the flash reader?
Postby Roman_TS » 29.03.16, 17:45
Yes, it's fully compatible :)
pcrecovery
Postby pcrecovery » 22.06.16, 19:50
I have read BGA132 with the BGA152 adapter. All you must do is CENTER the chip properly. The 132 pin chip is slightly smaller. Chip adapters have shims that you can replace/exchange for different size chips, but here, we have to simply center the chip in one direction. My chips have been the same length but smaller in width than 152.
sofiene
Postby sofiene » 04.10.17, 17:13
BGA132 is is bigger for BGA152 adapter !!!!!!!! who can take a picture ? thank you. :roll:
Postby Roman_TS » 21.12.17, 08:32
sofiene wrote:Source of the post BGA132 is is bigger for BGA152 adapter !!!!!!!! who can take a picture ? thank you. :roll:
It's not bigger. Chip should be placed on the plastic frame around the socket, which is on 2 mm higher than the surface with contacts.
Return to “PC-3000 Flash”
