Bit Locker
Posted: 03.04.18, 16:45
by Wanderson
Good afternoon I have problem to decrypt the PC3000 piece every time I put the password of the password invalid and I'm putting the correct password and this is not the first time can you help me?
Re: Bit Locker
Posted: 03.04.18, 16:51
Is partition damaged? Are there any other issues with the device?
It is set with data copy enabled? bit-locker is properly identified?
Try to mount with permit writing, check if windows can identify bitlocker protected volume. You are sure password is correct?
there are many factors that could result in this failure to decrypt, it is difficult to try to offer any support at the moment until you can state all you have tried already and condition of the media...
Re: Bit Locker
Posted: 03.04.18, 16:57
by digitalsupport
Try the recovery key instead of password to se if it makes any difference.
I had a few cases where password did not work, but im almost certain that client remembered the wrong password, but recovery key worked :)
Re: Bit Locker
Posted: 03.04.18, 18:11
by Wanderson
AJ2008 wrote:Source of the post Is partition damaged? Are there any other issues with the device?
the partition is corrupted and is bad block the disk does not even show on the computer
