Samsung HD105SI
Posted: 19.05.17, 16:10
by caputlatinum
The drive does not come ready. Heads function in donor drive and with donor heads in patient I was able to do a hot swap and extract Modules and Tracks. But I was not able to image after the swap. I was even able to build heads map. When I start imaging it just gets busy and does not continue. I try soft and hardware reset with no luck.
Is there a COM terminal connection for these drives?
Can anyone provide proper HOT SWAP instructions?
Thanks for any help.
Re: Samsung HD105SI
Posted: 26.05.17, 12:37
by Amarbir[CDR-Labs]
caputlatinum wrote:Source of the post The drive does not come ready. Heads function in donor drive and with donor heads in patient I was able to do a hot swap and extract Modules and Tracks. But I was not able to image after the swap. I was even able to build heads map. When I start imaging it just gets busy and does not continue. I try soft and hardware reset with no luck.
Hello ,
i have never worked on such a drive model but i am interested to know if you have solved it
Re: Samsung HD105SI
Posted: 26.05.17, 12:41
by caputlatinum
Nothing yet... I can't figure out what COM Port adapter to use. I get terminal busy.
Re: Samsung HD105SI
Posted: 26.05.17, 19:20
caputlatinum wrote:Source of the post Nothing yet... I can't figure out what COM Port adapter to use. I get terminal busy.
Hi ,
How About a Picture Of this Drive
Re: Samsung HD105SI
Posted: 26.05.17, 21:04
by caputlatinum
Will try to get that for you next week. TIME to go home.. have a good weekend.
