WD UITILITY NEED SOME ADDITIONAL FEATURES
zyana it solutions
Postby zyana it solutions » 26.12.23, 02:17
HI ALL I HOPE WE ALL NEED THESE FEATURES URGENTLY
1. ZERO FILLED SECTORS SHOULD BE MARKED IN DIFFERENT COLOR BECAUSE SOME TIME DRIVE BECOME ZERO AND WE ACTUALLY DON'T KNOW FROM WHERE TO CLONE.
2. WD UTILITY SHOULD HAVE A HDD RESTORE POINT LIKE MARVELL HAVE.
3. HARDWARE RETRY PIO MODE SPEED IT TOO LOW TO WORK NEED SPEEDUP IF POSSIBLE.
4. DATA IN 190 MODULE INFORMATION OF ZONES COULD BE SHOWN HEADWISE FOR BETTER RESULTS IN 190 DAMAGED CASE OR HEAD CUT.
5. ONE MORE POINT I AM THINKING MAY BE I AM WRONG THAT WHEN WE DO HOT SWAP WE FACE MANY PROBLEMS LIKE MATCHING DONOR, ACCURACY ,BUSY MODE
AND ALL SO IF COMPANY COULD USE A LOGICAL ENVIRONMENT WITH USING PATIENT MODULE AND CREATE A VIRTUAL DISK AT A LOCATION WITH PATIENT
MODULES LIKE IN RAM WITHOUT REMOVING THE PCB FROM PATIENT THEN IT HELPS TOO MUCH IN PLATTER DAMAGE CASES.
6. AND UFCORSE 190 V2 SED ENABLE RAW RECOVERY FOR THE LATEST DRIVES
THESE COULD HELP TO WORK BETTER WITH NEW CASES WHATS YOUR OPINION GUYS
ajay.mudhgill
Re: WD UITILITY NEED SOME ADDITIONAL FEATURES
Postby ajay.mudhgill » 31.12.23, 18:19
valid points...1 more thing, while using utility (t2 row data for desktop wd smr hdds) for recovery, imaging speed is 3-6 mbps,please do somthing to increase speed upto 20mbps is fine for me
