BUG: FBlite util not working correctly with latest version...
300ddr
Postby 300ddr » 19.08.17, 22:19
Trying loader utility says something to the effect of "overlay not compatible." Also, when trying to write ROM with something blocked (sa, 02, or 30), I get a "rom verification failed" error. Works fine on older version.
300ddr
Re: BUG: FBlite util not working correctly with latest version...
Postby 300ddr » 19.08.17, 22:26
"Rom verifying failed"... happens with PebbleBeach also.
Also happens with Shrek LT.
This sucks. It breaks the ROM after it fails too, so only option is BootROM or manually writing ROM using programmer.
lcoughey
Postby lcoughey » 21.08.17, 16:05
With BootROM being so quick and simple, it really isn't that much of an issue. Just the same, hopefully they'll provide a fix sooner than later.
300ddr
Postby 300ddr » 21.08.17, 18:54
More of an issue/hassle for USB drives without terminal connections. Also, would be nice if they added "blocking" options to Boot ROM menu.
