New PC-3000 Flash software ver. 7.0.2 is released
Posted: 29.07.15, 16:38
by Filipp_TS
Not much time has passed since PC-3000 Flash software ver. 7.0.1 became available, and the ACE Lab Team is ready with one more new release.
In the latest version, the PC-3000 Flash users will get the new TOOLS, which automate the routine operations helping to save your time:
The "Copy/Paste ECC" tool enables you to transfer the already detected ECC from one result to another
The "View ECC Information" tool helps you to know the type of the defined ECC and its format for a particular result
The "Reread Map Generator" tool significantly decreases the time for rereading in case of a large number of bad sectors
The "Block Cutting" tool is a new visual mode for cutting unused blocks from an already built image
The PC-3000 Flash software ver. 7.0.2 gives you an opportunity to recover data from such models of Flash drives that were not supported earlier or could be recovered only to a small extent:
New translator algorithm in EXTENSIONS for "EV268" controller
New translator algorithm in EXTENSIONS for "SM2685F" controller
The translator algorithms for "ITE1167" and "SSS6677" have been significantly improved for working with partially damaged translator tables
The PC-3000 Flash software ver. 7.0.2 makes it possible:
to search by mask in the GREP search
to cut bad bytes in one click (using the CTRL + left mouse button)
The PC-3000 Flash software ver. 7.0.2 also contains the following new functionality:
A lot of new ECC types
A lot of new XOR types
A lot of new ReadRetry types
The improved way of searching XOR in the list of XORs
To get the latest software versions, please contact sales@acelab.eu.com
Re: New PC-3000 Flash software ver. 7.0.2 is released
Posted: 05.08.15, 17:16
by Sergey_TS
therepairmasters wrote:Thanks Filipp ,
For This Information .Are You Folks Planning On a Version 4 Of The Hardware For PC3K Flash ?
The PC-3000 Flash hardware v.4 is under research and development.
The date of it's release is unknown because it hasn't even been tested yet.
Posted: 11.08.15, 15:08
Alexey TS wrote:The PC-3000 Flash hardware v.4 is under research and development.
So a V4 has been made already and is under testing?
Posted: 12.08.15, 17:46
by Roman_TS
This version of reader is not announce and not presented. I don't know anything about it right now. But, keep watch the news - probably we will know something new about it in next few month
