Seagate 1TB Rosewood
CS DATA RECOVERY
Postby CS DATA RECOVERY » 24.01.19, 09:42
hi
i have rosewood 1tb bad heads replaced new heads then drive gives 0capacity i have 2b and28 modules rewrited module 2b still 0 mb
i tried regen translator in terminal i got error.
DOS:0 Scan Unit
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
RECOV Servo Op=01A5 Resp=0005
RECOV Servo Op=00A5 Resp=0005
RECOV Servo Op=0095 Resp=0005
RECOV Servo Op=06DF Resp=0005
DSC
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22
RECOV Servo Op=0195 Resp=0005
DiagError 0000500EProcess Defect List Error
R/W Sense 00000002, R/W Error 041C0087, List Offset 00000000, List Index 00000000, File Error 00000000
F3 T>
any suggestions Pls....
Regards,
PAVAN KUMAR
CS DATA RECOVERY
Re: Seagate 1TB Rosewood
Postby DataMedics » 24.01.19, 13:08
CS DATA RECOVERY wrote:Source of the post any suggestions Pls....
Yeah, don't rush to use an M command so quickly on the next case. I hope you made a full backup of the system files first.
CS DATA RECOVERY
Postby CS DATA RECOVERY » 24.01.19, 13:31
yes sir i have taken backup all only 348 is missed actually i tried to restore 2b restored but not helped then i dont have another option thats why i did M comand
how can i solve it sir ..
Regards,
PAVAN KUMAR
CS DATA RECOVERY
vijayan
Postby vijayan » 26.12.19, 11:49
ONE HEAD BAD
REPLACE HEAD AFTER POSSIBLES DATA
Best regards,
Vijayan MBA
Raminfotech Data Recovery
call 7092114411/22
sky:raminfotech.vijayan
whatup:9841983643 / 46
Postby Amarbir[CDR-Labs] » 29.12.19, 12:41
vijayan wrote:Source of the post ONE HEAD BAD
Well,
On Basis Is Your Observation Based On Boss ,Can You Elaborate Please .Pavan Always check if your drive can write well on a unimportant module before you try stuff like this .Might be there is platter damage too
