wd20nmvw-11av3s2 Rom Transfer from usb pcb to Donor pcb
Paulfromsurrey
Postby Paulfromsurrey » 30.12.18, 01:55
I have Hard disk wd20nmvw-11av3s2 and I like to Transfer Rom from usb pcb to Donor pcb
I believe this drive has slow response issue so planing to change from usb pcb to sata
so i am looking for any documentation can help me to transfer the rom from this 2060-771961-001 rev A TO 2060-771960-000-REV A
This 2060-771961-001 has 12 pins so i like to know how we can setup com connection
how i can transfer rom information from one pcb to other pcb
Paul Patil
PC Plus Computing
Data Recovery Services
Business IT Services and Computer Repair Services
https://pcpluscomputing.com/services/Da ... -Services/
Re: wd20nmvw-11av3s2 Rom Transfer from usb pcb to Donor pcb
Postby digitalsupport » 30.12.18, 09:32
How to make a Com connection is right here https://forum.acelab.eu.com/viewtop ... 155&t=7397
How to transfer via Boot ROM mode you will find here: https://blog.acelab.eu.com/boot-rom ... rives.html
Paulfromsurrey
Postby Paulfromsurrey » 30.12.18, 23:31
Thank you Digital but the problem is in this model
there are two rows of 6 pins
not sure where the com connection should be connected which adapter is good to use
Paul Patil
PC Plus Computing
Blizzard
Postby Blizzard » 31.12.18, 17:44
You can use the WD 2.5 adapter. (see photo for connection)
Paulfromsurrey
Postby Paulfromsurrey » 09.01.19, 16:58
Thank you Blizzard
Paul Patil
PC Plus Computing
radovanhlavacek
Postby radovanhlavacek » 22.03.22, 11:16
Hello I have question on this topic... wd20nmvw-11av3s2, PCB 2060-771961-001 REV A. I found two SATA boards 2060-771961-001 REV A, REV P1, P2. Which PCB is compatible?
jcrepairhdd
Postby jcrepairhdd » 24.06.23, 03:41
radovanhlavacek wrote:Source of the post Hello I have question on this topic... wd20nmvw-11av3s2, PCB 2060-771961-001 REV A. I found two SATA boards 2060-771961-001 REV A, REV P1, P2. Which PCB is compatible?
Hi from my experience the most compatible would be 2060-771961-001 REV A. All screws line up as well unlike the others I have tried.
Return to “WD USB”
