WD60EFRX
gsharabidze
WD60EFRX
Postby gsharabidze » 18.12.18, 13:39
Hello everyone,
I want to do my drive diagnostics WD60EFRX-68L0BN1, 6TB to determine what problem(s) it have.
hare is a symptoms:
after connecting to PC3000 it have "bed" noises not clicking nose status register shows BSY. about 20-30 seconds later HDD is stops and status register shows ERR.
Thanks in advance.
Re: WD60EFRX
Postby AJ2008 » 19.12.18, 09:15
Do you see 'ERR' alone, or do you see 'ERR' 'DSC' 'DRD' status?
gsharabidze
Re: WD60EFRX
Postby gsharabidze » 19.12.18, 12:29
I see only ERR.
Re: WD60EFRX
Postby AJ2008 » 19.12.18, 16:42
After you see ERR, enter utility and autodetect family, it should remove ERR and show DSC DRD. Enter in Kernel mode, block SA access, repower and restart utility in Kernel mode. upload LDR and DIR, then see if SA checking is available. From here secure backup of adaptive modules at least (try to read all) and now you should be in better place to make repairs. But backup of SA modules is very important before any attempts to recover
Re: WD60EFRX
Postby AJ2008 » 20.12.18, 08:42
Yustik wrote:Source of the post guys when you see err press ctrl-alt-9 at pc3k utility and check extended error, debugstop code. it always says what is problem, no need to guess
It gives an error code which many users will still have no real idea what it relates to. These symptoms are suggestive of some error with some service information - which information specifically may not have any relation to the error code, and before attempts can be made to repair it we should always make a backup which is what I advised.
gsharabidze
Re: WD60EFRX
Postby gsharabidze » 27.12.18, 10:38
Sorry guys for late answer and thanks for discussion, so I tried ctrl+alt+9 and in the log windows I can't see any error codes. I see this:
Techno mode key
ROM Data size........................... : 1024 Kb
Modules directory address............... : 533 324
ROM Modules:
ROM version............................. : 03.27G
ROM F/W version......................... : 00030027
Overlay F/W version..................... : 03.27G
Servo F/W version....................... : 01.0L
Heads number............................ : 10
Heads number in use..................... : 10
Heads map............................... : 0,1,2,3,4,5,6,7,8,9
When I do View S.M.A.R.T. program shows: "Device error detected "ABR"".
Thanks.
gsharabidze
Re: WD60EFRX
Postby gsharabidze » 27.12.18, 14:19
After some test I have error: Zone allocation table................... : HDDs RAM reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Also drive is making some noise not clicking (I don't now English word describing this noise), its like a dial up modem sound if you remember that sound.
Thanks.
Maxim_TS
Re: WD60EFRX
Postby Maxim_TS » 28.12.18, 09:49
gsharabidze, if the drive makes bzzzz bzzzz noise, and you don't feel vibrations after power up, the heads might be parked on platters.
gsharabidze
Re: WD60EFRX
Postby gsharabidze » 28.12.18, 10:26
no I feel vibration, HDD powers up.
gsharabidze
Re: WD60EFRX
Postby gsharabidze » 04.01.19, 12:18
Happy new year to everyone.
Why I have: "Heads number............................ : 1". My HDD has 10 heads.
gsharabidze
Re: WD60EFRX
Postby gsharabidze » 04.01.19, 12:22
and above mentioned symptoms can be caused by PCB?
Maxim_TS
Re: WD60EFRX
Postby Maxim_TS » 11.01.19, 14:21
gsharabidze wrote:Source of the post above mentioned symptoms can be caused by PCB?
most possibly it's related to wrong head map in ROM. Try to set it to default, and restart the drive.
gsharabidze
Re: WD60EFRX
Postby gsharabidze » 18.01.19, 05:49
Thanks everyone for discussion
