Which chip do I have to change for the donor pcb
tonoarimany2012
Postby tonoarimany2012 » 03.12.18, 01:36
what chip i have to use for the donor pcb
thanks
donor board.jpg (12.59 KiB) Viewed 7963 times
hdd00
Re: Which chip do I have to change for the donor pcb
Postby hdd00 » 03.12.18, 05:48
For a donor Sata Pcb , IC2 need to be changed .
GuideRecovery
Postby GuideRecovery » 06.12.18, 15:31
you need to change U12 only ... BTW if you have pc3000 why bother soldering.
there are other good ways to swap ROM
Wasim Zafar
https://mindmergepk.com
Maxim_TS
Postby Maxim_TS » 25.12.18, 13:45
U12 is a HDD ROM chip. U14 is USB bridge chip. It's better to read the ROM via COM-port, then write it to SATA PCB, this way is more safe than unsoldering.
http://blog.acelab.eu.com/boot-rom- ... rives.html
Return to “WD USB”
