Sandisk SSD PLUS
eng.mas
Sandisk SSD PLUS
Postby eng.mas » 28.11.18, 16:13
Hello Guys,,
Is Sandisk SSD PLUS with this info suppueted by pc-3000 SSD utility?
Model Name:* SDSSDA2.5SSD drive
Controller Name:* SM2256S AB
Total Capacity:* 240GB
Best Regards,,
Re: Sandisk SSD PLUS
Postby Roman_TS » 28.11.18, 21:05
It's a new modification of Sandisk SSD Plus drive. Unfortunately we not working with it. Supported model is Sandisk Plus based on SM2246XT.
eng.mas
Postby eng.mas » 29.11.18, 08:05
Roman_TS wrote:Hello,
Thanks Roman,, I hope be supported in the next update..
Ohtic
Postby Ohtic » 03.05.19, 01:24
I also have a Sandisk SSD Plus
Model: SDSSDA-480G
Controller: SanDisk 20-82-00469-2
doesn't detect correctly. ID shows "Sandisk Milpitas SSD" and 0mb.
Will there be any support for this one too?
lcoughey
Postby lcoughey » 03.05.19, 19:38
Is that even a legit SSD Plus? That looks like an older flash drive controller to me.
Ohtic
Postby Ohtic » 06.05.19, 00:29
lcoughey wrote:Is that even a legit SSD Plus? That looks like an older flash drive controller to me.
It is. The same controller can be found on the WD Green SSD's.
lcoughey
Postby lcoughey » 06.05.19, 00:43
Well, this could be a good thing. There is a better chance of recovering with a chip-off recovery than the horrible read of this ssd with pc3k-ssd. If it is like the other models, you may need to be able to play with the voltages to get a decent read.
Return to “Other SSD”
