ROSEWOOD_A5 FAMILY TRASNLATOR PROBLEM
bayerecep
Postby bayerecep » 17.11.18, 17:50
i have rosewood_a5 family disk. this disk translator problem, first sector read but last sector not reading.
translator module damaged. this disk solution possible ?
Re: ROSEWOOD_A5 FAMILY TRASNLATOR PROBLEM
Postby DataMedics » 18.11.18, 01:49
Are you really sure it's a translator issue and not possibly one of the dozen other causes for this?(e.g. weak heads, a failed head, etc.)
Postby AJ2008 » 20.11.18, 15:17
bayerecep wrote:Source of the post Hello,
If translator module is damaged, first sector would not read. I assume someone has regen this translator without preserving MC or NRG entries resulting in part access to data area only.....
bayerecep
Postby bayerecep » 22.11.18, 23:16
28. I could not read the system file. I did the trasnlator regeranation. Now I can only read up to 300,000,000 of the 2TB capacity disc. Is there a way to solve this?
pclab
Postby pclab » 24.11.18, 15:29
You did everything that you shouldn't do...
GuideRecovery
Postby GuideRecovery » 27.11.18, 10:56
did you make backup of important sysfiles before regenerating translators ? if no, you are in trouble.
Wasim Zafar
https://mindmergepk.com
Nick_TS
Postby Nick_TS » 26.12.18, 10:41
Yeah, translator regeneration is not good idea :(
28 File Id (aka translator) has several sub-files. The most important is S-list (where defects from Pl-list and G-lists are actually gathered). The point is to read out the S-list, when you read S-list you have more chances to recover data without losses.
For more information please contact TS department :D
datasolution
Postby datasolution » 27.12.18, 16:18
Dear Sir,
I have same problem.model ST2000LM007-1R8174 .I have backup by autobackup from utility.Sys file 28 both copies and mod 2b were not readable.I tried single sec access on both sys files .I backup nrglist and sys 35 .than i tried translator regenerate by using m0,2,2,,,,22.but drive open up to 500 000 000 secs.now i clean nrglist and than writeback older backuped nrglist and than use m0,6,3,,,,,22 .than use sec edit result same.So pls help me if anyone have idea .Sir pls tell me slist belongs to which sys file or module so we can backup it in future.Before doing translator ntglist has 23 errs and after regenerate it shows 6.so i clear ntglist and restore older original nrglist.But not help.I have attached original nrglist backup before attempting translator.
NN : Init. LBA : Fin. LBA : Num : Flags : Comment
1 : 0 : 230 039 : 230 040 : 64 : b6
2 : 1 635 840 : 1 853 609 : 217 770 : 64 : b6
3 : 3 339 570 : 3 556 829 : 217 260 : 64 : b6
4 : 5 026 530 : 5 249 399 : 222 870 : 64 : b6
5 : 14 011 035 : 14 017 379 : 6 345 : 16 : b4
6 : 15 867 675 : 15 873 989 : 6 315 : 16 : b4
7 : 17 673 765 : 17 680 079 : 6 315 : 16 : b4
8 : 19 587 510 : 19 594 019 : 6 510 : 16 : b4
9 : 91 741 207 : 91 741 207 : 1 : 16 : b4
10 : 97 785 376 : 97 785 782 : 407 : 0 :
11 : 111 992 422 : 111 992 422 : 1 : 16 : b4
12 : 140 124 902 : 140 125 296 : 395 : 0 :
13 : 158 770 049 : 158 770 436 : 388 : 0 :
14 : 171 057 934 : 171 057 934 : 1 : 16 : b4
15 : 172 541 564 : 172 541 934 : 371 : 0 :
16 : 283 746 769 : 283 746 769 : 1 : 16 : b4
17 : 295 201 129 : 295 201 129 : 1 : 16 : b4
18 : 329 913 750 : 329 914 065 : 316 : 0 :
19 : 489 852 908 : 489 852 908 : 1 : 16 : b4
20 : 493 120 277 : 493 126 576 : 6 300 : 16 : b4
21 : 494 103 077 : 494 109 421 : 6 345 : 16 : b4
22 : 495 092 897 : 495 099 241 : 6 345 : 16 : b4
23 : 496 082 717 : 496 089 271 : 6 555 : 16 : b4
in this list i can see b4 b6 and 0.
thanks and regards.
27-12-2018 21-48.txt
(2.98 KiB) Downloaded 474 times
datasolution
Postby datasolution » 28.12.18, 07:32
Finally :thumbup: :thumbup: :thumbup: Problem solve by writing nrglist original backup.
