Menus doesn´t update properly
edbrandt
Postby edbrandt » 12.11.18, 20:39
I have a strange problem in PC-3000 Flash (ver. 7.2.6). It seems like the menu on the right pane doesn´t update when I try to open the Transformation graph. So when I click "Transformation graph" in the left side menu, the graph doesn´t show on the right side - instead I see the menu item "Transformation graph" on right and left side. Have a look:
What am I missing.. How can I reset the settings to default view?
Btw: I did try a reboot :)
-Espen
Re: Menus doesn´t update properly
Postby Roman_TS » 13.11.18, 08:20
Hello Espen,
I recommend you to download PC-3000 Flash 7.2.9 which is already in your updatebox. It's already include some bugfixes. I'm sure, this bug has been already fixed too.
edbrandt
Postby edbrandt » 13.11.18, 11:04
Thanks Roman. Tried to update, but same problem.. I'll create a ticket.
-Espen
Postby Roman_TS » 13.11.18, 11:21
Problem is solved in ticket. Looks like - case too :D
edbrandt
Postby edbrandt » 14.11.18, 09:07
Problem solved..
Reason for menus not updating was that current task containined too many unions and old attempts of auto-solution (due to try-and-fail). Cleared from Task-folder, and all good.
Thank you Roman :)
-Espen
