DiamondMax Plus 9 Beeping noise
Paulfromsurrey
Postby Paulfromsurrey » 19.10.18, 04:57
I have this Maxtor Drive
Diamond Plus 9 160GB ATA/133 HD
LBA 320173056
MFg Date 17 FEB 2005
Made in Singapore
CODE YAR41BWO
K,M,G,D
SN Y48gdl9e
6Y160P0042811
Drive was dead not spining on visual inspection one of the chips smoothie seems like had crack or chipped
I replaced the pcb board with another Maxtor Drive
LBA 320173056
MFg Date 01 FEB 2005
Made in Singapore
CODE YAR41BWO
N,M,C,D
SN Y48ECB9E
6Y160P0042811
after pcb board is replaced Drive make beeping noise
here is the sample of the noise
https://drive.google.com/file/d/1nKpNVq ... sp=sharing
I also checked the plater is running fine not jammed
you think head might be stuck
I did not transfer the rom in this case from patient to donor drive
Paul Patil
PC Plus Computing
Data Recovery Services
Business IT Services and Computer Repair Services
https://pcpluscomputing.com/services/Da ... -Services/
Re: DiamondMax Plus 9 Beeping noise
Postby AJ2008 » 22.10.18, 09:20
You do not need to transfer ROM on these.
Probably there is a problem with the motor - by beeping noise do you mean a sort of 'tune' that repeats every few seconds?
Paulfromsurrey
Postby Paulfromsurrey » 24.10.18, 21:36
Here is the beeping noise
https://drive.google.com/file/d/1nKpNVq ... 5ESsJ/view
Let me know if you can help
Paul Patil
PC Plus Computing
Paulfromsurrey
Postby Paulfromsurrey » 24.10.18, 21:56
when i adapted new pcb with same chip
here is pic of pc3000
https://drive.google.com/file/d/1yLU5sC ... sp=sharing
here is audio i can hear
https://drive.google.com/file/d/162eepJ ... sp=sharing
Please let me know if you can help me
Paul Patil
PC Plus Computing
Return to “Maxtor”
