I am looking for ROM/LDR combination that I can try to attempt to gain access to the SA on this case I have. Any help is appreciated!
Drive model is WD5000BMVW-11AJGS3
firmware is 0016001C
family FBLite 2.5"
I hope someone can share it
ROM/LDR for WD5000BMVW-11AJGS3
- storeC Padua
Re: ROM/LDR for WD5000BMVW-11AJGS3
You will need original ROM and a LDR of corresponding FW revision. Using a donor ROM will not allow access to SA or data
- storeC Padua
Thank you for your answer.
I have this situation
Upload LDR with a corresponding revision that matches your ROM, and then check how it behaves
