how to setup com connection to WD10JMVW
Paulfromsurrey
Postby Paulfromsurrey » 18.09.18, 21:59
I just received this hard drive for data recovery and drive is not being recongnized by pc3000 or deepspar
Here is the information about this drive
WD10JMVW-11AJGS4
It is 1 tb Drive
I believe the family for this drive is based on this information i found on another website
FBlite
WD FBlite family and its models:
WDC WD10JMVW-11AJGS2
WDC WD10JMVW-11AJGS0
WDC WD10JMVW-11AJGS3
WDC WD10JPVX-00JC3T0
WDC WD10JPVX-22JC3T0
WDC WD5000BMVW-11AJGS0
WDC WD5000BMVW-11AJGS2
WDC WD10JPVX-08JC3T5
when we tried to run utility it is giving me techno key error
Please let me know how
Paul Patil
PC Plus Computing
Data Recovery Services
Business IT Services and Computer Repair Services
https://pcpluscomputing.com/services/Da ... -Services/
Re: how to setup com connection to WD10JMVW
Postby AJ2008 » 19.09.18, 08:47
These are much easier to work when converted to SATA - I would recommend diagnosing over SATA first.
Paulfromsurrey
Postby Paulfromsurrey » 19.09.18, 15:56
Where I can find compatible pcb board information
WD10JMVW-11AJGS4
WD PCB BOARD IS 2060-771961 001 REV B
Paul Patil
PC Plus Computing
Postby AJ2008 » 19.09.18, 16:28
Paulfromsurrey
Postby Paulfromsurrey » 19.09.18, 16:49
Thank for the information so I Can just ignore the Rev information
so in this case
PCB BOARD IS 2060-771961 001 REV B = 2060-771960 Rev could be any number
=2060-771959
=2060-771939
Paul Patil
PC Plus Computing
Paulfromsurrey
Postby Paulfromsurrey » 20.09.18, 00:42
I was able to find the sata board and changed the rom chip and lets see if can work
drive spin ok but does not come to ready state
one time it shows all the make and model and serial no
most of the time it stay busy can not identify family
any help
Paul Patil
PC Plus Computing
Maxim_TS
Postby Maxim_TS » 24.09.18, 16:32
Paulfromsurrey, follow this manual: http://blog.acelab.eu.com/pc-3000-h ... oblem.html
Paulfromsurrey
Postby Paulfromsurrey » 27.01.19, 04:13
Thanks Max I was able to recover all my data
Paul
PcPluscomputing.com
Computer Repair and Data Recovery Services in Surrey,bc
Paul Patil
PC Plus Computing
Return to “WD USB”
