hi to all
i have same h.d.d wd
i want h.d.d repair bad sector
i do logic test then defects to g-list then move g-list to plist and translator regenator g-list and plist
but not work
i do convert phyical and add plist but no answer
please help
thanks
bad sector
Re: bad sector
Most probably srface in very bad condition and contain lot of bad sectors.
Defect lists are not infinity and big number of defects overflow defect list modules.
what 'not work'?
Please describe whole drive behavior after these steps.
sepid wrote:Source of the post i do logic test then defects to g-list then move g-list to plist and translator regenator g-list and plist
but not work
what 'not work'?
Re: bad sector
thanks filip
I fully explain
This HDD 2tb 2.5 is from the family sherk LT 2.5
All modules are healthy
spin without trouble and no sound spin ok
I did a logic test
I gave the transmission of broken sectors in the g-list
Then I transferred the g-list to the P-list
In the end I got the runner translator regenation
When I test hard everything is okay
But when it writes data on the hard drive
Comes back to the failures of the sectors
I fully explain
I did a logic test
Re: bad sector
Well I have the same problem, the only solution that I've found so far (if you don't want your information on hdd) is to format the HDD using PC3000 Format (You can use MRT or Delphi too, but PC3000 is the most effective) use transfer gl to pl after the format and clear the G-List, Use the translator regeneration and clear the S.M.A.R.T,turn the hdd on and off, afterward start the test from the start till the End of the sectors (Surface, Write, Read), by this time the hdd is mostly intact and there's only few bad sectors.
