ST8000DM003 Can't Modify System File 93
Postby DataMedics » 12.07.18, 16:02
So I've got here an 8Tb drive model ST8000DM003 which came in with failed heads. The heads were replaced with a perfect donor set from an exact match drive. The only difference between the two is three days on the date of manufacture.
After swapping the heads and unlocking the ROM this is what I was getting in terminal:
Code: Select all
Tech Unlock Handshake: 0x33693C60
Reply:
Rst 0x0100MAF00550001
No HOST FIS-ReadyStatusFlags 0002A1A1
IDLE1
I could work in terminal, but ATA registers stayed stuck at BSY. I tried numerous times to modify System File 93 and disable the media cache and other unnecessary functions but the changes never took no matter how many times I tried it.
Heads were re-tested back in the donor and they're 100% functional still, so I know it's not any damage to the heads.
Finally, having run out of options, I followed the Ace method here: http://blog.acelab.eu.com/pc-3000-h ... error.html
(there was one NRG entry, but I can deal with the partial access issue later)
Now after doing the translator regen (which took 7-8 min and spit out a number of errors) the ATA registers do go to DRD DSC but the drive still won't ID or allow anything to work over ATA, I can still only work in terminal. Modifying System file 93 is still not working as well. On startup the drive is spitting out a lot of MCMT errors, so I'm pretty certain the media cache is at fault here, but I can't seem to do anything about it since modifications to modules don't take.
Anyone think they know of a method to force it to write the changes?
Re: ST8000DM003 Can't Modify System File 93
Postby DataMedics » 19.07.18, 23:19
No ideas? Anyone here? :(
