heads replacement
ictsec.areait
heads replacement
Postby ictsec.areait » 12.07.18, 14:54
I've a WD 1TB green, WD10EADX DCM=HHNNNT2MHB, with heads failure.
I also have these 2 similar WD 1TB green disks:
WD10EARS, DCM=HGNYHT2MAB
WD10EAVS, DCM=HANNHT2CAB
Can I use one as heads donor?
Thanks in advance
cuumaytinh
Re: heads replacement
Postby cuumaytinh » 12.10.18, 16:51
See mode factory in table untility If mode is same may be can used.
