ST2000LM007-FW:SBK2 - Rd Sys File 28 Err
jojo2012
Postby jojo2012 » 09.07.18, 15:41
Hi there,
I have this drive, spin up fine, DRD e DSC ok without any clicks, full ID, but with the capacity 0.
I handled to read and save 1B, 35, 93 Sys files, but unfortunately with the 28 I get reading errors even with option "read by one sector".
Now I will try again with the module 2B but if I'm not mistaken gave me the same error reading.
NRG-list have 25 entries.
If we can’t read the translator and save it, it's a big problem :(
Any hint, ideas, trick or trips on how overcome this problem?
Thanks so much
Re: ST2000LM007-FW:SBK2 - Rd Sys File 28 Err
Postby AJ2008 » 09.07.18, 16:47
Try to send "F,,22" at terminal, refresh ID and check - sometimes this may help, but if 028 is damaged then you must find other way to preserve translator entries.
Can you read over ATA, Terminal, sys file and module table at alternate copies - compare in winhex or other hex editor and try to make one good copy of it.
Also, can you see start of 028 file? Maybe there are no entries you need to worry about. You can post here what you can read and maybe we can advise whether translator regen will cause issues or not.
Postby Amarbir[CDR-Labs] » 09.07.18, 17:29
AJ2008 wrote:Source of the post Try to send "F,,22" at terminal, refresh ID and check - sometimes this may help, but if 028 is damaged then you must find other way to preserve translator entries.
Try reading from both heads and post here please ,Lets see what you get and help reconstruct it
jojo2012
Postby jojo2012 » 10.07.18, 08:33
Ok, thanks AJ2008 and Amarbir.
I'll try and let you know.
Although I seem to have already tried to read via terminal and ATA from both the heads.
jojo2012
Postby jojo2012 » 11.07.18, 08:50
I was able to read the translator piece by piece. The initial part is damaged.
I can not attach the files. It tells me that the extension (bin) is not valid.
AJ2008- The command F,,22 worked, meaning that after refreshing ID I got the right capacity. The translator unfortunately I can not read it.
jojo2012
Postby jojo2012 » 13.07.18, 08:21
Some update, also 348 SYS file is unreadable.
In one way or another I'll let you know if I could solve it.
I do not know if I have no reply because there is no solution or because I have not explained well, or because my English is bad.
Bruno
Postby Bruno » 17.07.18, 15:07
Hi all,
i have same HD with same FW, but no ID no SN.
after prepare the ROM to unlock by Utility, the drive starts and DRD DWF DSC are green.
Here is the log:Selected family......................... : A5, Rosewood_A5
Model by ID............................. : <HDD ID NOT READ>
Tech Key...
Error starting command "En Tech" (ABR)
Detecting SA Phys Sct Size...
Rd Sys File: vol = A, FID = 32A, Copy = 000...
Root Sys File Rd Err!
Rd Sys File: vol = 0, FID = 20D, Copy = 000...
Receiving file FILE_0_20D_0, length = 1572864
Parsing container segment....... Flash ROM image
Segment: CUSTFW
Parsing segment....... CUSTFW
End parsing segment... CUSTFW
End parsing container segment... Flash ROM image
Buff Root FAT searching in RAM......... Ok
Searching volume 0 file table in RAM....
Rd Sys File: vol = 1, FID = 202, Copy = 000, Offs = 0, Part size = C...
Receiving file FILE_1_202_0, length = 12
Rd Sys File: vol = 1, FID = 202, Copy = 000, Offs = 0, Part size = 144...
Receiving file FILE_1_202_0, length = 324Ok
Searching volume 3 file table in RAM....
Rd Sys File: vol = 1, FID = 203, Copy = 000, Offs = 0, Part size = C...
Receiving file FILE_1_203_0, length = 12
Rd Sys File: vol = 1, FID = 203, Copy = 000, Offs = 0, Part size = E64...
Receiving file FILE_1_203_0, length = 3684Ok
Searching SMP RAM FID in RAM............
Rd Sys File: vol = 1, FID = 204, Copy = 000, Offs = 0, Part size = C...
Receiving file FILE_1_204_0, length = 12
Rd Sys File: vol = 1, FID = 204, Copy = 000, Offs = 0, Part size = 570...
Receiving file FILE_1_204_0, length = 1392Ok
Searching Non Resident G-List FID in RAM
Searching CFW OVL FID in RAM............
I could save the importet Sys-Files1B, 28, 35 and 93.
I think the Problem is the SYS-File 32A. But in the SYS-File List i cant find it. please see below:
Test : Get Sys File list from HDD (terminal, "T>y")
FID Vol FD Location Size
42 0 FC000042 75F0 1000
43 0 FC001043 14110 1000
44 0 FC002044 20C30 1000
45 0 FC003045 2D750 1000
46 0 FC004046 3A270 1000
47 0 FC005047 46D90 1000
48 0 FC006048 538B0 1000
49 0 FC007049 603D0 1000
4A 0 FC00804A 6CEF0 1000
4B 0 FC00904B 75F0 1000
4C 0 FC00A04C 797EA 1000
4D 0 FC00B04D 84E83 1000
0 0 FC00C000 1 5000
330 0 FC00D330 586 50000
331 0 FC00E331 5D6 50000
203 0 FC00F203 A95C 2000
20D 0 FC01020D 406 180000
20E 0 FC01120E 4673 180000
226 0 FC012226 47F3 330000
0 0 FC00C000 CB21 5000
330 0 FC00D330 D0A6 50000
331 0 FC00E331 D0F6 50000
203 0 FC00F203 1747C 2000
20D 0 FC01020D CF26 180000
20E 0 FC01120E 11193 180000
226 0 FC012226 11313 330000
21D 3 FC30021D B69A 40BE6000
21E 3 FC30121E 32C80 32C80000
21F 3 FC30221F 19640 759B000
220 3 FC303220 20C83 54DD000
221 3 FC304221 20BDC 4A000
222 3 FC305222 20C30 1D000
223 3 FC306223 181B9 1487000
181 3 FC307181 75E6 A000
182 3 FC308182 14106 A000
183 3 FC309183 20C26 A000
184 3 FC30A184 2D746 A000
185 3 FC30B185 3A266 A000
186 3 FC30C186 46D86 A000
187 3 FC30D187 538A6 A000
188 3 FC30E188 603C6 A000
189 3 FC30F189 6CEE6 A000
18A 3 FC31018A 75E6 A000
18B 3 FC31118B A84A A000
18C 3 FC31218C 1A9444 A000
20F 3 FC31320F 759B 1000
210 3 FC314210 140BB 1000
211 3 FC315211 20BDB 1000
212 3 FC316212 2D6FB 1000
213 3 FC317213 3A21B 1000
214 3 FC318214 46D3B 1000
215 3 FC319215 5385B 1000
216 3 FC31A216 6037B 1000
217 3 FC31B217 6CE9B 1000
218 3 FC31C218 759B 1000
219 3 FC31D219 A7FF 1000
21A 3 FC31E21A 1A93F9 1000
30F 3 FC31F30F 760D 36000
310 3 FC320310 1412D 36000
311 3 FC321311 20C4D 36000
312 3 FC322312 2D76D 36000
313 3 FC323313 3A28D 36000
314 3 FC324314 46DAD 36000
315 3 FC325315 538CD 36000
316 3 FC326316 603ED 36000
317 3 FC327317 6CF0D 36000
318 3 FC328318 760D 36000
319 3 FC329319 A871 36000
31A 3 FC32A31A 1A946B 36000
14F 3 FC32B14F 960F 12000
150 3 FC32C150 1612F 12000
151 3 FC32D151 22C4F 12000
152 3 FC32E152 9621 96000
153 3 FC32F153 16141 96000
154 3 FC330154 22C61 96000
155 3 FC331155 96B7 2F000
156 3 FC332156 161D7 2F000
157 3 FC333157 22CF7 2F000
158 3 FC334158 96E6 4000
159 3 FC335159 16206 4000
15A 3 FC33615A 22D26 4000
173 3 FC337173 9943 8000
174 3 FC338174 16463 8000
175 3 FC339175 22F83 8000
15B 3 FC33A15B 96EA 60000
15C 3 FC33B15C 1620A 60000
15D 3 FC33C15D 22D2A 60000
15E 3 FC33D15E 974A 60000
15F 3 FC33E15F 1626A 60000
160 3 FC33F160 22D8A 60000
161 3 FC340161 97AA 60000
162 3 FC341162 162CA 60000
163 3 FC342163 22DEA 60000
164 3 FC343164 980A 60000
165 3 FC344165 1632A 60000
166 3 FC345166 22E4A 60000
167 3 FC346167 986A 60000
168 3 FC347168 1638A 60000
169 3 FC348169 22EAA 60000
16A 3 FC34916A 98CA 40000
16B 3 FC34A16B 163EA 40000
16C 3 FC34B16C 22F0A 40000
203 3 FC34C203 A95C 2000
344 3 FC34D344 6 100000
345 3 FC34E345 106 200000
346 3 FC34F346 306 100000
31C 3 FC35031C 673 3C00000
32F 3 FC35132F 4273 400000
31B 3 FC35231B 4B23 14000
31E 3 FC35331E 4B37 7D000
31F 3 FC35431F 4BB4 258000
19 3 FC355019 5781 2000
1A 3 FC35601A 4E0D 1000
1B 3 FC35701B 53B2 3CF000
1C 3 FC35801C 53B2 4E000
1F 3 FC35901F 53EB 396000
1D 3 FC35A01D 53B2 39000
1E 3 FC35B01E 53EB 15000
20 3 FC35C020 5400 381000
300 3 FC35D300 4E0C 1000
28 3 FC35E028 5783 ED000
29 3 FC35F029 5783 7B000
35 3 FC360035 5991 121000
36 3 FC361036 5870 121000
37 3 FC362037 5870 242000
56 3 FC363056 5AB2 281000
301 3 FC364301 9603 1000
100 3 FC365100 4E0E 10000
101 3 FC366101 4E1E 10000
102 3 FC367102 4E30 50000
103 3 FC368103 4E80 30000
104 3 FC369104 4EB0 20000
105 3 FC36A105 4ED0 10000
106 3 FC36B106 4EE0 10000
107 3 FC36C107 4EF0 10000
108 3 FC36D108 4F00 10000
109 3 FC36E109 4F10 50000
10A 3 FC36F10A 4F60 30000
10B 3 FC37010B 4F90 20000
10C 3 FC37110C 4FB0 10000
10D 3 FC37210D 4FC0 10000
110 3 FC373110 4E2E 2000
115 3 FC374115 95FF 4000
116 3 FC375116 9609 5000
131 3 FC376131 9604 5000
132 3 FC377132 8215 1001000
93 3 FC378093 7194 2000
209 3 FC379209 A95E 1000
133 3 FC37A133 9D7A 1000
134 3 FC37B134 9D8D 3FE000
135 3 FC37C135 9D7C 4000
304 3 FC37D304 759C 5000
305 3 FC37E305 75A1 1000
306 3 FC37F306 75C5 10000
307 3 FC380307 75C2 1000
14E 3 FC38114E 960E 1000
16D 3 FC38216D 990A 10000
16E 3 FC38316E 991A 29000
30A 3 FC38430A 7193 1000
30E 3 FC38530E 75F1 1C000
BF 3 FC3860BF 75C3 2000
C0 3 FC3870C0 75D5 1000
137 3 FC388137 9D81 1000
138 3 FC389138 9D8A 1000
171 3 FC38A171 9D28 1000
177 3 FC38B177 9D88 2000
178 3 FC38C178 A18B 20000
139 3 FC38D139 9D29 2000
13A 3 FC38E13A 9D80 1000
13B 3 FC38F13B 9D87 1000
13D 3 FC39013D 9D2B 1000
13E 3 FC39113E 9D2C 1000
13F 3 FC39213F 9D2D 40000
140 3 FC393140 9D82 3000
141 3 FC394141 9D6D D000
1D0 3 FC3951D0 7196 23C000
1D1 3 FC3961D1 73D6 111000
199 3 FC397199 7CCF 400000
143 3 FC398143 9D8B 1000
1D2 3 FC3991D2 73D2 2000
136 3 FC39A136 755B 20000
17D 3 FC39B17D 757B 2000
17F 3 FC39C17F 757D 1E000
183 3 FC39D183 AEA0 4000
187 3 FC39E187 AEB1 4000
13C 3 FC39F13C 9D1F 9000
17A 3 FC3A017A 9D7A 13000
20B 3 FC3A120B A1AB 1000
309 3 FC3A2309 A1AC 1000
69 3 FC3A3069 A503 10000
68 3 FC3A4068 A513 1000
21B 3 FC3A521B A501 2000
1E0 3 FC3A61E0 A1AD 352000
1E1 3 FC3A71E1 A1AD A9000
1E6 3 FC3A81E6 626 4D000
1E3 3 FC3A91E3 A4FF 1000
180 3 FC3AA180 A514 8000
B7 3 FC3AB0B7 A51C 1000
308 3 FC3AC308 A51D 3000
30B 3 FC3AD30B A532 4000
30C 3 FC3AE30C A520 11000
30D 3 FC3AF30D A531 1000
17B 3 FC3B017B 9D8C 1000
348 3 FC3B1348 6326 7B9000
71 3 FC3B2071 5D33 220000
1EB 3 FC3B31EB A90C 50000
1F9 3 FC3B41F9 6DBD 2000
181 3 FC3B5181 AE5F 40000
182 3 FC3B6182 AE9F 1000
1FE 3 FC3B71FE AEA4 4000
184 3 FC3B8184 AEA8 1000
35E 3 FC3B935E AEB5 640000
363 3 FC3BA363 B4F5 7B000
365 3 FC3BB365 B598 100000
1DC 3 FC3BC1DC 7547 1000
1DD 3 FC3BD1DD 7548 1000
1DE 3 FC3BE1DE 7549 8000
203 3 FC34C203 1747C 2000
344 3 FC34D344 CB26 100000
345 3 FC34E345 CC26 200000
346 3 FC34F346 CE26 100000
31C 3 FC35031C D193 3C00000
32F 3 FC35132F 10D93 400000
31B 3 FC35231B 11643 14000
31E 3 FC35331E 11657 7D000
31F 3 FC35431F 116D4 258000
19 3 FC355019 122A1 2000
1A 3 FC35601A 1192D 1000
1B 3 FC35701B 11ED2 3CF000
1C 3 FC35801C 11ED2 4E000
1F 3 FC35901F 11F0B 396000
1D 3 FC35A01D 11ED2 39000
1E 3 FC35B01E 11F0B 15000
20 3 FC35C020 11F20 381000
300 3 FC35D300 1192C 1000
28 3 FC35E028 122A3 ED000
29 3 FC35F029 122A3 7B000
35 3 FC360035 124B1 121000
36 3 FC361036 12390 121000
37 3 FC362037 12390 242000
56 3 FC363056 125D2 281000
301 3 FC364301 16123 1000
100 3 FC365100 1192E 10000
101 3 FC366101 1193E 10000
102 3 FC367102 11950 50000
103 3 FC368103 119A0 30000
104 3 FC369104 119D0 20000
105 3 FC36A105 119F0 10000
106 3 FC36B106 11A00 10000
107 3 FC36C107 11A10 10000
108 3 FC36D108 11A20 10000
109 3 FC36E109 11A30 50000
10A 3 FC36F10A 11A80 30000
10B 3 FC37010B 11AB0 20000
10C 3 FC37110C 11AD0 10000
10D 3 FC37210D 11AE0 10000
110 3 FC373110 1194E 2000
115 3 FC374115 1611F 4000
116 3 FC375116 16129 5000
131 3 FC376131 16124 5000
132 3 FC377132 14D35 1001000
93 3 FC378093 13CB4 2000
209 3 FC379209 1747E 1000
133 3 FC37A133 1689A 1000
134 3 FC37B134 168AD 3FE000
135 3 FC37C135 1689C 4000
304 3 FC37D304 140BC 5000
305 3 FC37E305 140C1 1000
306 3 FC37F306 140E5 10000
307 3 FC380307 140E2 1000
14E 3 FC38114E 1612E 1000
16D 3 FC38216D 1642A 10000
16E 3 FC38316E 1643A 29000
30A 3 FC38430A 13CB3 1000
30E 3 FC38530E 14111 1C000
BF 3 FC3860BF 140E3 2000
C0 3 FC3870C0 140F5 1000
137 3 FC388137 168A1 1000
138 3 FC389138 168AA 1000
171 3 FC38A171 16848 1000
177 3 FC38B177 168A8 2000
178 3 FC38C178 16CAB 20000
139 3 FC38D139 16849 2000
13A 3 FC38E13A 168A0 1000
13B 3 FC38F13B 168A7 1000
13D 3 FC39013D 1684B 1000
13E 3 FC39113E 1684C 1000
13F 3 FC39213F 1684D 40000
140 3 FC393140 168A2 3000
141 3 FC394141 1688D D000
1D0 3 FC3951D0 13CB6 23C000
1D1 3 FC3961D1 13EF6 111000
199 3 FC397199 147EF 400000
143 3 FC398143 168AB 1000
1D2 3 FC3991D2 13EF2 2000
136 3 FC39A136 1407B 20000
17D 3 FC39B17D 1409B 2000
17F 3 FC39C17F 1409D 1E000
183 3 FC39D183 179C0 4000
187 3 FC39E187 179D1 4000
13C 3 FC39F13C 1683F 9000
17A 3 FC3A017A 1689A 13000
20B 3 FC3A120B 16CCB 1000
309 3 FC3A2309 16CCC 1000
69 3 FC3A3069 17023 10000
68 3 FC3A4068 17033 1000
21B 3 FC3A521B 17021 2000
1E0 3 FC3A61E0 16CCD 352000
1E1 3 FC3A71E1 16CCD A9000
1E6 3 FC3A81E6 D146 4D000
1E3 3 FC3A91E3 1701F 1000
180 3 FC3AA180 17034 8000
B7 3 FC3AB0B7 1703C 1000
308 3 FC3AC308 1703D 3000
30B 3 FC3AD30B 17052 4000
30C 3 FC3AE30C 17040 11000
30D 3 FC3AF30D 17051 1000
17B 3 FC3B017B 168AC 1000
348 3 FC3B1348 12E46 7B9000
71 3 FC3B2071 12853 220000
1EB 3 FC3B31EB 1742C 50000
1F9 3 FC3B41F9 138DD 2000
181 3 FC3B5181 1797F 40000
182 3 FC3B6182 179BF 1000
1FE 3 FC3B71FE 179C4 4000
184 3 FC3B8184 179C8 1000
35E 3 FC3B935E 179D5 640000
363 3 FC3BA363 18015 7B000
365 3 FC3BB365 180B8 100000
1DC 3 FC3BC1DC 14067 1000
1DD 3 FC3BD1DD 14068 1000
1DE 3 FC3BE1DE 14069 8000
What can i do to resolve this issue?
Please Help.
jojo2012
Postby jojo2012 » 24.07.18, 09:41
Case solved. Cloned 99,9%.
PC3K had the solution and it was enough to exploit it.
Thanks anyway to AJ2008 and Amarbir for the hint / help.
jojo2012
Postby jojo2012 » 24.07.18, 09:55
Bruno wrote:Source of the post Hi all,
Tech Key...
Segment: CUSTFW
0 0 FC00C000 1 5000
Please Help.
Sorry Bruno I had another problem and I hope you have solved it
Consultant
Postby Consultant » 18.01.19, 10:13
jojo2012 wrote:Source of the post Case solved. Cloned 99,9%.
Have a Rosewood drive with the exact same issue as yours, namely correct ID, but 0GB capacity.
All critical sys files could be read, except 28, from either head copy, even with reading by one sector. Heads resistance test in terminal show normal values.
Would you be able to share what was the PC3K solution that helped solve it for you please?
Consultant
Postby Consultant » 18.01.19, 17:09
So, executed the F,,22, which gave SA access.
All mods are fine, except 2B.
First 7 sectors of each copy in 2B are unreadable.
NRG has entries, as many Rosewoods do, even when healthy:
F3 T>V40
Nonresident GList 4 entries returned
Total entries available: 4
0 6B508 40 0 0 0 3
1A450A 6D75E 40 0 1 0 1021D5
A10CE3B 129 0 3A880 0 0 E930B
B08D605 116 0 41A8D 0 0 9FB89
Can anyone share any ideas of what the best solution at this would be?
Nick_TS
Postby Nick_TS » 24.01.19, 07:52
Consultant wrote:Source of the post Would you be able to share what was the PC3K solution that helped solve it for you please?
1. Please upload module tables for a task in Utility status.
2. Read 28 system via terminal sector-by-sector.
3. Upload here saved 28 sys file with DE AD signature.
Consultant
Postby Consultant » 25.01.19, 02:28
Dmitriy_TS wrote:Source of the post Hello,
Customer declined and wanted the drive back. Sorry.
