Head compatability for WD40PURX
Imnew
Postby Imnew » 09.07.18, 14:50
I have HDD WD40PURX-64NZ6Y0, family apollo.
HDD is not detecting and needs head change.
I have got Donor HDD WD40PURZ- 85TTDY0, but family is same as apollo.
When I am opening Mod 47 and the microjog editor to see whether heads are compatible or not, everything is 00 in microjog editor.
How to find a compatible head ?
Re: Head compatability for WD40PURX
Postby DataMedics » 09.07.18, 15:32
I wouldn't worry much about microjogs. More important is matching the right part of the DCM, date, country.
Postby Amarbir[CDR-Labs] » 09.07.18, 17:30
Imnew wrote:Source of the post Hello,
can you share photos of label from both patient and donor drives
Imnew
Postby Imnew » 10.07.18, 07:48
The country for both is thailand.
DCM of patient is HANNNTJMHB and date is jan 2017
DCM of Donor is HHNNHT2MHB and date is may 2018.
Sending the photo of label also.
Postby DataMedics » 11.07.18, 02:25
T2 and TJ DCM codes are not often cross-compatible. You might get lucky and it'll work, but not often. I'd keep looking for another donor.
Imnew
Postby Imnew » 11.07.18, 08:33
Thanks a lot. I will try to look for another donor
Postby AJ2008 » 11.07.18, 10:56
DataMedics wrote:Source of the post T2 and TJ DCM codes are not often cross-compatible. You might get lucky and it'll work, but not often. I'd keep looking for another donor.
T2 and TJ should be ok, Tx is not compatible with Vx
northwind
Postby northwind » 11.07.18, 11:46
AJ2008 wrote:Source of the post
I agree with this.
Postby DataMedics » 11.07.18, 21:26
Maybe I'm just overly picky with my donors. I just know what's always worked for me.
I guess there's only one way for the OP to find out...
