SM2256K all sectors zeroed
northwind
Postby northwind » 02.07.18, 12:28
I got this Transcend SSD with SM2256K.
It stays in BSY.
After shorting and choosing Adata utility for SM2256K, drive IDs OK
id ok.JPG (108.29 KiB) Viewed 5940 times
But when I read sectors via utility, all sectors look the same, and garbled. Sector 0:
Sector 2048:
All sectors look the same.
When I create translator, I get this
Service area scanning
block: 0x0004........................... : ISP
block: 0x0005........................... : ISP
Completed
Blocks of translator is not found
and then,
Translator build
User blocks (Found)..................... : 0x00000000
Min version: 0xFFFFFFFF; Max version: 0x0000
Completed
Completed
Test completed
Indeed, if I create a new task, all sectors read OK (all green), but they are all empty (zeroed).
Any ideas?
Re: SM2256K all sectors zeroed
Postby Roman_TS » 03.07.18, 08:41
Transcend drives are not supported officially by PC-3000. Maybe you can send this drive to us for research.
SM2246 - have the same translator structure, LDR and other modules. But starting from SM2256 - all models might be very different. Even if both are based on the same controller like SM2256K (ADATA is supported, Transcend is not supported).
northwind
Postby northwind » 03.07.18, 09:50
Alright, thanks for the input.
Gonna ask the client if they're willing to have their drive sent for research.
Return to “Other SSD”
