Samsung 960 EVO 256GB
MasterT
Postby MasterT » 12.06.18, 21:23
SSD is detected like this:
device manager.png (2.63 KiB) Viewed 12770 times
SSD Properties in Device Manager:
ssd properties.png (18.56 KiB) Viewed 12770 times
In Windows Disk Management it looks like this:
disk management.png (8.11 KiB) Viewed 12770 times
If i try to access it i get the following error:
error message.png (3.44 KiB) Viewed 12770 times
So in order to recover data i tried to start new task in Data Extractor but surprise, SSD is not detected:
task creation.png (10.01 KiB) Viewed 12770 times
Any hint on how to proceed?
Thank you very much.
northwind
Re: Samsung 860 EVO 256GB
Postby northwind » 13.06.18, 09:57
When you connect the drive to SATA0 in PC3K how does it behave?
MasterT
Postby MasterT » 13.06.18, 11:14
Cannot connect to SATA0 because Samsung 960 EVO has PCI-express interface. And it can't be plugged in M.2 to SATA interface.
Postby Roman_TS » 13.06.18, 14:30
860 EVO - is a SATA based SSD. 960 EVO - is a PCI-E drive. So, which is yours? :)
MasterT
Re: Samsung 960 EVO 256GB
Postby MasterT » 13.06.18, 14:40
It is 960 EVO.
Postby Roman_TS » 14.06.18, 10:55
PCI-E based drives are not supported by PC-3000 SSD for now. But we are working under solution which will be present in 2019.
Return to “Other SSD Samsung”
