I don't believe I've seen this before. Drive is SED encrypted. I moved ROM to SATA PCB and shorted TV9/10, still can't read ROM (same if I blocked head contacts) -- "SED Locked." I removed and manually read ROM in a ROM reader... it looks almost completely encrypted.
Is there no way to access firmware on this kind of drive with encrypted ROM?
Copy of ROM here: https://slack-files.com/T041AF3B4-FB2QX290T-43c038afb9
Thanks,
Brian
WD10SMZW-11Y0TS0 with encrypted ROM...
Re: WD10SMZW-11Y0TS0 with encrypted ROM...
300ddr, it's a new, currently unsupported Palmer family.
We will appreciate if somebody knows how to deal with them
Regarding ACE Team, our Developers are working on it now.
Maxim_TS wrote:300ddr, it's a new, currently unsupported Palmer family.
I do, you can outsource
Hi Doomer,
Are you saying you can access the FW on these drives? If so, then at least there is hope for the future
300ddr wrote:Source of the post Hi Doomer,
Are you saying you can access the FW on these drives? If so, then at least there is hope for the future.
Yes, on these and on Charger too (2TB 7mm)
300ddr wrote:Source of the post I don't believe I've seen this before. Drive is SED encrypted. I moved ROM to SATA PCB and shorted TV9/10, still can't read ROM (same if I blocked head contacts) -- "SED Locked." I removed and manually read ROM in a ROM reader... it looks almost completely encrypted.
Thanks,
Brian
I Am Able You See Al Usual Signatures In This ROM Sir ,No Issues With That .
