ST4000LM024
Miodrag
ST4000LM024
Postby Miodrag » 29.03.18, 11:46
The drive spins normal but the status is constantly busy, so can't load any information from the drive. When it is load with F3 Arch (common) I get the access to the terminal and here is a terminal response:
Boot 0x80MMD00040001
SpinUp
TCC:001E
Trans
Rst 0x80MMD00040001
SIM_ReadyDiskFile failure1 :
ErrorCode : 0x00001002
SIM_ReadyDiskFile read again
SIM_ReadyDiskFile failure2 :
DSC PASS
SIM Error 1002 LBA 000000000002EA56 FD FCFFF3FF
RW Error 44090081
SIM FileFD=FC30121E ErrorCode=44090081 DiscLBA=000000000002EA57 Duration=00000359 ms
SIM Error 1002 LBA 000000000002EA57 FD FCFFF3FF
RW Error 44090081
No HOST FIS-ReadyStatusFlags 0002A181
The drive has a locked diagnostic port so I can't do anything, the only solution was to try with patching rom, but that didn't help to, because this drive isn't supported by PC3000 yet. Is anybody have a similar problem or have some suggestion what else I can try besides waiting for ACE to implement this patch/family in the PC3000...
shahi
Re: ST4000LM024
Postby shahi » 30.03.18, 10:04
I've a same drive, busy for long then ready and again busy once tries to access sector, and can't patch
looking for guideline
Nick_TS
Re: ST4000LM024
Postby Nick_TS » 24.04.18, 20:59
Hello Shahi,
Please send us ROM from this drive.
Trouse
Re: ST4000LM024
Postby Trouse » 03.05.18, 01:56
Is there any update to this? Are there any patched ROMs for this with an adjusted head map? I need to get a ROM that has Head 0 off and another with Head 1 off in the heads map ad the RAM heads map wont register and shows a constant "ABR". I have the original ROM that i can send to anyone that can help. Thanks!
