WD10EZEX FULL OF BAD SECTORS (STRANGE)
shahi
Postby shahi » 22.02.18, 23:53
The drivd arrived with HSA issue.
Swapped and GOT ID
But data area full of UNC;BAD SECTORS.
SOLVED 32 ISSUE AS IT WAS FOUND BAD. Still inaccessible data area.
All critical module looks fine
Any advice would be highly appreciated
Re: WD10EZEX FULL OF BAD SECTORS (STRANGE)
Postby digitalsupport » 23.02.18, 12:09
Can you access any LBA at all?
What is the outcome of a head test?
Are heads still working ok in donor drive?
shahi
Postby shahi » 23.02.18, 12:23
Used 3 DONOR so far, all with same symptom
Yes, the HEAD is working fine while taken back
The HEADS are working fine without issue.
According to ACE TS - there is an "unknown error code 4593"
