SM2258 Based Intel SSD (m.2)
Ohtic
Postby Ohtic » 20.02.18, 23:41
I have a Intel Based m2 SSD. Model number is SSDSCKKW010X6.
It has a SM2258G Controller.
Detects correctly at full capacity but will not read any Data.
Receive UNC error through whole SSD.
After a long power cycle (30 mins) i was able to read the first 23mill.
Reads with UNC after.
Is there going to be support for SM2258 based controllers?
Re: SM2258 Based Intel SSD (m.2)
Postby Roman_TS » 21.02.18, 12:09
We are going to add SM2258 in nearest 3-4 month. But I'm not sure that Intel model will be supported because it has different Firmware and Technological Mode. Our developers didn't make decision about it yet.
Postby Amarbir[CDR-Labs] » 25.02.18, 08:38
Ohtic wrote:Source of the post I have a Intel Based m2 SSD. Model number is SSDSCKKW010X6.
Again get it ready and take block size to 1 and leave a few thousand sectors were it was unc and try again
lcoughey
Postby lcoughey » 27.04.18, 15:14
I have an Intel SSD Pro 5400s Series with the SM2258G controller here that gets stuck at BSY on any command to read and won't ID. Any word on a more precise date if and when support will be added?
Postby Roman_TS » 01.05.18, 08:55
Intel are always modifying default firmware in third-party controllers that they are use in their drives. It's completely different in compare with default SM2258 firmware. As I know, Intel drives based on SM2258 will not be added in next release. But some A-DATA, Sandisk and others - will appear.
shahi
Postby shahi » 13.03.19, 16:48
Intel 5400 pro- IDs properly but full of UNC. Can be dealt?
Postby Roman_TS » 14.03.19, 07:45
Hello. List of supported Intel drives you can find here:
https://blog.acelab.eu.com/pc-3000- ... dated.html
    Intel X18;
    Intel X25;
    Intel 320;
    Intel 510;
    Intel 710;
If your drive return full ID but instead of real data can provide access only to zeroes - then it has a trouble with translator microprogram. Technological Mode recovery is required.
Return to “Other SSD”
