ST2000LM007-1R8174 Update Mask BSY upon any command
baldric
Postby baldric » 19.02.18, 11:07
I have this drive
Model : ST2000LM007-1R8174 after unlock, it is able to read the HDD ID.
BSY whenever i click any command.
It wont read any sector.can't backup modules.need help recovering files.
baldric
Re: ST2000LM007-1R8174 Update Mask BSY upon any command
Postby baldric » 20.02.18, 05:52
forgot to upload the terminal log. :lol:
Terminal.txt
(1.51 MiB) Downloaded 788 times
Send Status: COMRESET seen
CSpd= 3Gbps
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/7
F3 7>m100
Diagnostic Port Locked
F3 7>
diagnostic port is locked when i try to perform this command.
Filipp_TS
Postby Filipp_TS » 20.02.18, 10:37
How to bypass locked terminal and deal with Rosewood drives you can read in these articles:
http://blog.acelab.eu.com/pc-3000-f ... rives.html
http://blog.acelab.eu.com/pc-3000-f ... ackup.html
Also, welcome to Tech. support service:
Postby Amarbir[CDR-Labs] » 25.02.18, 08:57
baldric wrote:Source of the post Hi,
I have this drive
Well,
Unlock Terminal first then take backup of SA ,Do not try any stunts like you do in F3 series Seagates .
baldric
Postby baldric » 25.02.18, 09:49
Amarbir[CDR-Labs] wrote:Source of the post
I have this drive
Well,
i already follow the steps in
to unlock the terminal.
i think there's head problem with the drive, i perform the same unlock procedure to another ST2000LM007 it can be unlock. but it's facing translator issue(maybe).
can you please help me on that case?
viewtopic.php?f=154&t=9613
:D
Nick_TS
Postby Nick_TS » 27.02.18, 19:29
Hello Baldric,
Could you read 348 system file on this drive?
