It look similar with Type 3 in AceLab DB, but i check pin 1A and 1B and they are not GND..
Any tips??
Thanks in advance
AJ2008 wrote:Source of the post I think the problem isnt to know where GND is, but rather that it does not correlate with GND in the pinmap ACE have for this pattern which suggests the map Ace have is not suitable.
Unfortunately I do not have the pinmap for this so I cannot help
Multi-COM wrote:Source of the post We got pinout for this card and are able to read it (if you own a MR30 microSD adapter from us you can buy a socket that you will just put on adapter and it will allows to read this card ) ....... but......in those cards Samsung make ECC as its own way (why it's doesn't surprise me....self made ECC ???) so not common ECC scheme. But once you get it reader SA/Data/ECC structure for sector is 36/1024/1248. Good luck
DataMedics wrote:Source of the post I've been hoping to play with this feature. I'd sworn off getting into doing monoliths myself, but with the spider board and this new update, I'm thinking it might be worth re-investigating it.
So going forward I'll probably be just testing if there's a ready built solution that works, otherwise just outsource it.
