Segate ST2000LM007 ROSEWOOD HDD
firstdata
Postby firstdata » 14.02.18, 06:44
I have two drives of the same ST2000LM007. They issued ‘Error initializing microprogramming tables’ during utility Initialization of PC3000, HDD ID not being detected, following the below message.
(MC POR Duration): 000000D1AD
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
LED:0x000000BD FAddr:0x00009062
Any ideas what may be causing this and solutions?
Thanks for any help.
Masterclass
Re: Segate ST2000LM007 ROSEWOOD HDD
Postby Masterclass » 15.02.18, 05:37
Cause: Some failure in SA
Solution: Find and fix this error
Postby AJ2008 » 15.02.18, 10:51
Device has security features preventing access to important service area information - you can apply a patch to the ROM on this to bypass this security and access SA
some SA information is damaged or corrupt preventing good initialization of the media. You need to first gain access then find the problem. It is probably related to MediaCache or problems with the relocation processes but due to peculiarities with this model you should always ensure you make a full backup of any accessible service information, pay special attention to translator module.
firstdata
Postby firstdata » 19.02.18, 09:52
I could not do anything because getting access. I want more detailed method of approach.
Filipp_TS
Postby Filipp_TS » 20.02.18, 10:38
so, what an error you get after ROM patching?
Terminal mode is available?
firstdata
Postby firstdata » 21.02.18, 03:36
I applied 'Tech mode unlocking preparation, patch', but could not access.
Terminal mode not available, but BSY DRD DSC PHY register ON.
Maybe NAND flash ROM damaged?
The log is
Test : Read ROM
Reading ROM to profile folder
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\ST2000LM007\Data\ROM\
File : ROM.bin
Switching HDD power supply OFF
Switching HDD power supply ON
Flash type inx... 0x00000000
Flash size....... 0x00100000
Flash prm dmp.... 0xEF 0x14 0x08 0x0B 0x05 0x9F 0x01 0x03 0x3C 0x20 0x40 0x04 0x00 0x01 0x00 0x00
Receiving file flash.bin, length = 1048576
WARNING!
In Boot Code mode HDD have shortened commands set!
For full-mode work via utility you have to switch HDD power supply OFF/ON!
Unlocking Diag Mode (terminal)...
Error unlocking Diag Mode: Terminal : reply timeout error
Unlock Diag Mode, terminal, "Lombard, Megalodon" : Ok
Detecting SA Phys Sct Size...
Can not detect SA phys secotr size by ATA!
Postby Amarbir[CDR-Labs] » 25.02.18, 08:42
Something is not right here .YOu need to program original rom back and apply the patch i think you applied wrong patch .Please check proper blog and redo this if my observation is correct
Nick_TS
Postby Nick_TS » 27.02.18, 19:34
firstdata wrote:Source of the post Test : Read ROM
File : ROM.bin
Try to select manually Rosewood A5 family, and read ROM in this family again.
