Of course I could use 8 HDD docs but that's a bit nuts.
I was thinking of using a PCI-e 6 port SATA controller and two onboard SATA controllers. Or I could go with 2X 4 port controllers.
If this is a good approach, can anyone recommend a reliable controller? I've heard bad things about SYBA.
whats' the easiest way to connect 8 drives to a PC?
- thatdellguy
Re: whats' the easiest way to connect 8 drives to a PC?
LSI SAS 9211-8i
I noticed that one has RAID.... Is there a non raid version?
In the pic it doesn't show 8 ports. I'm assuming I can just not use the RAID function?
- thatdellguy
Can be flashed into IT mode.
Look for a mini-SAS to 4x SATA cable.osity wrote:Source of the post...In the pic it doesn't show 8 ports.
Oh the connecters on the card are mini SAS?
So I guess you don’t get any cables with it.
it sounds like I would need the card and two mini Sas to 4x SATA cables...
I just ordered it with the a bunch of cables. Thank you!
- thatdellguy
1. card
2. flash to IT mode.
3. two sets of cables.
That card is a beast... it can handle 256 drives
It needs to be HBA card not RAID controller - RAID controller often will not mount drives unless they are an active RAID configured by the card. HBA will simply mount them as individual disks.
Any of the Microsemi HBA 1000 Series adapters should do the trick - https://www.microsemi.com/product-direc ... 60-hba1000
If you are looking for a short-term quick and dirty approach, another alternative is an 8 port USB3/eSATA hotswap enclosure by Startech - https://www.startech.com/HDD/Enclosures ... 358BU33ERM
It seems flashing to IT mode was unnecessary.
Well,
A HBA SAS with Card To SATA Cables .Or a SAS Raid card that can be flashed to HBA
startech 8 drive enclosure - $391
or
or couple of 5 port stat multiplier cards on ebay $17 each....
you know, sata is cascadeable, you plug your sata cable into the port multiplier and it becomes 5 sata ports.
you need the appropriate sata controller - but I think its standard with all the recent (last few years) sata cards, check your sata specs.
or
skype: wayne_horner
Alandata Data Recovery
Good day,
We received a RAID 6 NAS unit with 16 drives NAS, 6TB/ drive. All drives are in working condition but a LUN has done missing after reboot.
What is a better (faster) approach to due with this case?
- d_d_recovery
- User
You need a none RAID SAS controller. If you get a SAS controller you can attach SATA or SAS drives to it.
