Seagate ST4000LM016 Heads Alignment
odedshankar
Postby odedshankar » 05.02.18, 01:39
Hi Guys,
Just got an Seagate ST4000LM016 with bad heads and I am planning to get a donor and perform heads swap.
I am suspecting that it will be a - with the alignment as heads are connected with direct screw without pivot.
Did anyone did those already and have some input?
Cheers
Re: Seagate ST4000LM016 Heads Alignment
Postby Amarbir[CDR-Labs] » 05.02.18, 18:55
Well,
No problem just go ahead ,But remember its a seagate and even before you order spares check heads under microscope
odedshankar
Postby odedshankar » 05.02.18, 22:26
thanks arambir, will do.
