When I run a scan on an MFT and INDX file I get a prompt to "Run in the background" Yes or no.
What is this?
what is this new "Run in the background" prompt
Re: what is this new "Run in the background" prompt
From here:
"A lot of different processes can now be run in the background:
A process of copy creating;
A process of copy creating by the map;
Saving files, log-file has been made separately for different process (for simultaneously running common and background processes);
Analysis of NTFS, FAT, ExFAT, XFS, UFS, HFS+, ReiserFS;
Scan of MFT table;
Search and (or) analysis of file systems structures;
GREP search;
RAW recovery;
Snapshots using legend and heads map became available for Encrypted drives"
You will see a tab for Processes so you can see what processes are still running.
Scan of MFT table;
GREP search;
RAW recovery;
Ver 7.1 of Pc 3000 Flash also has background function .
Why would I want to run any of it in the background?
I haven't had any luck finding any tasks that will run in background simultaneously. I thought it would be cool if I could save selected files from two different partitions to a destination drive at the same time, but it wouldn't allow me.
Is this feature designed for people that have slower workstations? I dont find the PC3K UDMA uses up much resources...
Perhaps the PC3K express does...
- digitalsupport
- User
For a bad drive : If it was possible to queue several of the same tasks it would make sense. Example create 3 x "map of marked" with individual settings, not run them simultaneously but in a queue.
For a ok drive: like lcoughey suggestion, run all tasks simultaneously (will stress the drive)
So some kind of "switch" to control that processes are to be queued or run simultaneously.
The only advantage I've found is that you can still browse the file system while imaging in the background. So you can begin a full sector clone, then without stopping it you can go in and search for specific files that are important to the customer.
But, it would be nice to be able to disable this message. Or, better yet, dump the pop-up message and just add a "Send to background" option in the imaging task somewhere should anyone actually want to do this.
DataMedics wrote:Source of the post you can still browse the file system while imaging in the background. So you can begin a full sector clone, then without stopping it you can go in and search for specific files that are important to the customer.
That's pretty neat I guess if you use it..... thanks for the detailed reply.
Does it slow down the background process timewise when you run it in the background?
- thatdellguy
I wish it was gone or at least turned off...
ok...
I've had a chance to use my PC3K more lately and that "run in background" pop up is annoying.
Well,
They are unifying software code between all their products this is also one reason for such stuff .I can share some info in pc3k flash were it has some features actually useful for hdd tool only
Hello Amarbir,
Could you share this information?
Amarbir[CDR-Labs] wrote:Source of the post I can share some info in pc3k flash were it has some features actually useful for hdd tool only
Sir ,
As Code Unification of All PC3K Tools is going on for example sometimes on the top left side were we have hdd details etc we will see same box but no info is we are working with flash system and many other small small things ,The users have to get use to stuff like this
