microSD noname 4GB
minea
microSD noname 4GB
Postby minea » 08.01.18, 15:40
Hello. I have a problem with one monolith. noname 4gb microSD. I have a screenshot but I can not find xor and ecc. I know that ecc will be for xor. the memory chip is ECD798CA K9ABG08U0A. I did not find any solution in solbase, I tried to fold it myself but no effect. Please help. Maybe someone did such a card. I do not have a controller. The card had no other markings. Only capacity and clase.
http://mkmydata.pl/mkmydata.pl1.jpg
http://mkmydata.pl/mkmydata.pl2.jpg
Re: microSD noname 4GB
Postby Roman_TS » 09.01.18, 08:09
Hello. Please reach our technical support through ACELab TS portal on: ts.acelab.eu.com. We will guide you.
Postby AJ2008 » 09.01.18, 10:49
Load page designer to look at bitmap view to check quality of dump looks good
minea
Postby minea » 10.01.18, 08:24
Postby AJ2008 » 10.01.18, 09:33
Use bitview to check if structures look good.
run RAW recovery to check for files - if none are found, apply inversion then try again - as this is 4GB it may be old and not with XOR. If no files are found in RAW with and without invert, then it will be some XOR. If Xor analysis finds no results then maybe you have older software with old XOR database or PC3000 cannot support it. do you have photo of the card (map side)?
minea
Postby minea » 10.01.18, 12:03
this card type number 3 did not have any descriptions on the reverse. Detects me fat directories and not all files in the raw image. nothing is visible after the inversion.
Postby AJ2008 » 10.01.18, 12:43
Can you upload the dump? If this is possible I can look at it for you and assuming I can solve it I can tell you the solution. Since you can see FAT structures before invert or XOR I imagine this should be not so difficult case.
minea
Postby minea » 11.01.18, 12:46
Maybe it will be better if I give you ID and pass TV and look in this way. to send TV coordinates to your email?
Postby AJ2008 » 11.01.18, 12:58
ok, this is ok :)
minea
Postby minea » 11.01.18, 13:21
went to the email
Postby AJ2008 » 11.01.18, 13:37
I will connect in next few minutes
