SSHD ST500LM000 Drive Busy FW: DEMD
shahi
Postby shahi » 30.12.17, 20:57
Can't access to T, Tried this patch, still can't access T, http://blog.acelab.eu.com/pc-3000-f ... -work.html
Following message appeared, Drive Spins normally
Code: Select all
Boot 0x40M
 Spin Up
 RECOV Servo Op=0100 Resp=0005
 Trans.
   SOC PSM Mode =    0001      Atomic
   SOC PSM Command = 0000      Flash Read
   SOC PSM Status =  0011      Invalid PSM Parm
Clump Parametrics:
                    Clump = FE55
                 DataType = 0000
                 ModeFlag = 03
               EraseCount = FFFFFFFF
           EraseFailCount = 07
         ProgramFailCount = 07
            WeakReadCount = 1F
    UncorrectableECCError = 07
---SOC PSM Command History---
 Cmd#/PsmCmd    Clump     Offset     Length     LbaMid     LbaLow   LbaBits39To32 Options   Status    DestClump  DestOffset
     0000       FE55       FEAA       0008       8000       2F5A       0000       C000       0011       C207       AE73
     0F00       FE55       FEAA       0008       8000       2F5A       0000       C000       0011       C207       AE73
     0E01       0058       0000       0008       8000       394B       0000       C000       0080       C207       AE73
     0D00       0181       0000       0008       8000       394B       0000       C000       0080       C207       AE73
     0C01       013B       16E0       0020       0000       0000       0000       C000       0080       C207       AE73
Flash Statistics:
BridgePSMDriverID = 0x0009
FlashID 98D7 8493 72D7
Flash Manufacturer: Toshiba19nm
Flash Capacity = 00008 GB MLC
Combo Mode
NumberOfClumps =    0x0400
LBAsPerCluster =    0x0020
LBAsPerClumpMLC =    0x4000
LBAsPerClumpSLC =    0x2000
ClustersPerClumpMLC =    0x0200
ClustersPerClumpSLC =    0x0100
DefragClumpThresholdInSectors =    0x2000
UserSLCMaxSizeInClumps =           0x0180
NumberOfPotentiallyWrittenClusters =    0x0002
DefectListRevisionKey         0x0002
SLC Clumps                    0x01A7
 ActiveClumpInfo
   Active Journal             Clump 013B   Offset 1700
   Active Anchor              Clump 0003   Offset 1D60
   DType 0000   Read Cache          Clump 03C9   Offset 0000
   DType 0001   Read Boot           Clump 036E   Offset 0000
   DType 0008   Dirty Write Cache   Clump 0057   Offset 0000
   DType 0009   Dirty Boot          Clump 00DD   Offset 0000
   DType 0011   Clean Write Cache   Clump 0052   Offset 0000
   DType 0012   Clean Boot          Clump 00E2   Offset 0000
   DType 001A   SIM                 Clump 0058   Offset 0020
   DType 001B   DRIVEFW             Clump 0074   Offset 0000
--- ALF RFS Recorder ---
--- Recorder prints backwards: newest to oldest ---
 IARCount    Status       Clump      ClumpSentinel      FunctionOrigin
 ALFRecorder:
   ReadAnchorEntry
   ReadAnchorEntry
   ReadAnchorEntry
   ReadAnchorEntry
   ReadAnchorEntry
   FindActiveAnchorClump
   FindActiveAnchorOffset
   RetrieveAnchor
   ReadAnchorEntry
   ReverseActiveAnchorPointer
   ReadAnchorEntry
   ReadALFTables
   UseJournalToFinishALFTablesRestore
   ReadJournalLog
   ReadJournalLog
   SaveALFTablesToFlash
   RebuildALFTablesUsingMetaData
   TableAdjustForMoveClump
   TableAdjustForMoveClumpToCondemn
   GetNewActiveClump
   GetNewActiveClump
   ReconstructNodesInActiveClump
   GetNewActiveClump
   GetNewActiveClump
   GetNewActiveClump
   GetNewActiveClump
   TableAdjustForMetaData
   ReplaceNodePhysical
   GetNewActiveClump
   GetNewActiveClump
   EraseTableSystemClump
   WriteALFTables
   SaveNewAnchorToFlash
   AdvanceActiveAnchorPointer
   WriteAnchorEntry
   WriteAnchorEntry
   WriteJournalLog
   AdvanceActiveJournalPointer
   IssueALFRequest
   ReadDataFromFlash
   IssueALFRequest
   WriteDataToFlash
   JournalEntryForReplaceNode
   AddEntryToJournal
   ReplaceNodePhysical
   IssueALFRequest
   ReadDataFromFlash
 ERROR:  Flash LED 9C1D - ReplaceNode Error replacing node - Invalid Clump
   Target Start LBA   0000000080002F5A
   Target Length      00000008
   Clump              FE55
Clump Parametrics:
                    Clump = 0400
                 DataType = 0000
                 ModeFlag = 00
               EraseCount = 00000000
           EraseFailCount = 00
         ProgramFailCount = 00
            WeakReadCount = 00
    UncorrectableECCError = 00
     0009       0400       4000       0008       0020       0002       0002       C000       0080       C207       AE73
     0009       FE55       FEAA       0008       8000       2F5A       0000       C000       0080       C207       AE73
Flash Statistics:
Combo Mode
SLC Clumps                    0x01A7
 ActiveClumpInfo
 ALFRecorder:
   RetrieveAnchor
   ReadAnchorEntry
   ReadAnchorEntry
   ReadALFTables
   ReadJournalLog
   ReadJournalLog
   GetNewActiveClump
   GetNewActiveClump
   GetNewActiveClump
   GetNewActiveClump
   GetNewActiveClump
   GetNewActiveClump
   ReplaceNodePhysical
   GetNewActiveClump
   GetNewActiveClump
   WriteALFTables
   WriteAnchorEntry
   WriteAnchorEntry
   WriteJournalLog
   IssueALFRequest
   ReadDataFromFlash
   IssueALFRequest
   WriteDataToFlash
   AddEntryToJournal
   ReplaceNodePhysical
   IssueALFRequest
   ReadDataFromFlash
   IssueALFRequest
   IssueALFRequest
   IssueALFRequest
   IssueALFRequest
   ReplaceNodePhysical
Re: SSHD ST500LM000 Drive Busy FW: DEMD
Postby DataMedics » 30.12.17, 21:35
If I had to guess, I'd suspect it's a bad NAND on the SSHD. But, perhaps someone else who's seen this specific log message could confirm it.
Postby Amarbir[CDR-Labs] » 31.12.17, 04:29
Shahi,
Might Be You Need a New PCB As This PCB Flash NAND Chip Might Be Defective
shahi
Postby shahi » 31.12.17, 11:32
Ok, Let me search for a DONOR First
lcoughey
Postby lcoughey » 02.01.18, 15:35
I've recovered several of these without changing the heads or opening them up.
Postby AJ2008 » 09.01.18, 10:58
It is bad NAND. There is no need to open it, but if patch is not working then you need to use donor PCB with same FW revision and swap ROM to it, then 'flush' NAND content to force reloading of patient adaptive data back into donor NAND
