How to handle Seagate SSHD-ST500LM000-FW: DEMC-Terminal Locked
jojo2012
Postby jojo2012 » 20.11.17, 15:59
Hi Guys,
I’d like to know as handle these beasts.
The patient after power ON, stays BSY, then after a while, it get DRD and DSC state, but terminal is locked and it give the terminal output in attached.
I applied the Kahuna patch and I was able to unlock terminal. So I saved ROM and 28, 35, 1B SYS file. 93 I can't read it.
So as after the command “F3 T>/OI” I got the error “SOC PSM Status = 0017 Flash Erase Failure”, I have ordered a compatible (equal) PCB, rewritten the original ROM, but I got the error “ERROR: Flash Led 9C17 - RestoreALFTablesToDRAM Failed - could not recover data from Tables Clump” and the drive does not spin up at all.
ACE TS said to try with another PCB.
I think it's a problem with SSD flash failure, but at the moment I do not know how to fix it ... do you have any idea?
Thanks so much in advance
Jojo
Terminal.txt
(6.39 KiB) Downloaded 860 times
Nick_TS
Re: How to handle Seagate SSHD-ST500LM000-FW: DEMC-Terminal Locked
Postby Nick_TS » 22.11.17, 12:15
Hello Jojo,
jojo2012 wrote:Source of the post I applied the Kahuna patch and I was able to unlock terminal. So I saved ROM and 28, 35, 1B SYS file. 93 I can't read it.
Can you send any other commands in the terminal?
Is FW version of the drive is DEMC? Are you sure that you patched the ROM?
Please send us the log report when you patch the ROM by Kahuna patch.
jojo2012
Postby jojo2012 » 23.11.17, 10:41
Hello Dmitriy,
here other commands in terminals output.
As you can see the FW is DEMC and if it's possible I can attach the original ROM and the patched one
Maybe I don't have the log report when I patch the ROM....I'll see.
Thank you
Jojo
Terminal_after_patch.txt
(6.45 KiB) Downloaded 795 times
Terminal_NAND_Reinitialize.txt
(92.94 KiB) Downloaded 828 times
Filipp_TS
Postby Filipp_TS » 01.12.17, 06:42
Hello Jojo,
Better to check this case remotely.
Please contact Technical support dept. ts.acelab.eu.com
Postby Amarbir[CDR-Labs] » 01.12.17, 11:57
Jojo,
i am very interested how TS solved this case to give us the brief if indeed they did
jojo2012
Postby jojo2012 » 17.12.17, 17:10
Hello Jojo,
Hello Filipp,
the TK you closed it, because you told me to try with other PCBs and I did not have all these PCBs. The Kahuna Patch in my case did not work.
I had to solve it in another way.
Kind regards
Jojo
vijayan
Postby vijayan » 29.01.18, 07:56
Clump Parametrics:
Clump = 0182
DataType = 007F
ModeFlag = 03
EraseCount = FFFBFBFF
EraseFailCount = 03
ProgramFailCount = 07
WeakReadCount = 1F
UncorrectableECCError = 07
---SOC PSM Command History---
Cmd#/PsmCmd Clump Offset Length LbaMid LbaLow LbaBits39To32 Options Status DestClump DestOffset
0000 0182 0000 16C7 0000 0000 0000 C000 0001 C207 CCB8
0600 0182 0000 16C7 0000 0000 0000 C000 0001 C207 CCB8
0500 0003 0880 0001 0000 0000 0000 C000 0080 C207 CCB8
0400 0003 08A0 0001 0000 0000 0000 C000 0080 C207 CCB8
030A 0003 08A0 0020 0000 01E1 0000 C200 0026 C207 CCB8
Flash Statistics:
BridgePSMDriverID = 0x0009
FlashID 98D7 8493 72D7
Flash Manufacturer: Toshiba19nm
Flash Capacity = 00008 GB MLC
Combo Mode
NumberOfClumps = 0x0400
LBAsPerCluster = 0x0020
LBAsPerClumpMLC = 0x4000
LBAsPerClumpSLC = 0x2000
ClustersPerClumpMLC = 0x0200
ClustersPerClumpSLC = 0x0100
DefragClumpThresholdInSectors = 0x2000
UserSLCMaxSizeInClumps = 0x0180
NumberOfPotentiallyWrittenClusters = 0x0002
DefectListRevisionKey 0x0002
SLC Clumps 0x01A7
ALFRecorder:
End of ALF Recorder Trace
possibles data recovery
1.NEW PCB CHANGES NO RESULT
2.ROM COPY NEW PCB ROM NO RESULT
3.DONER PCB + PATIENT ROM FIX NO ERROR NO TERMINAL
4.DONER PCB +DONER ROM FIX PATIEND HDD SPINING BUT ID NOT COMEING
FLASH ROM :8GB FLASH CHIP PROBLEM ?
HOW TO READ THIS CHIP?
ANY SOLUTION SEND MAIL
Best regards,
Vijayan MBA
Raminfotech Data Recovery
call 7092114411/22
sky:raminfotech.vijayan
whatup:9841983643 / 46
Filipp_TS
Postby Filipp_TS » 20.02.18, 14:00
vijayan wrote:Source of the post ERROR: Flash Led 9C17 - RestoreALFTablesToDRAM Failed - could not recover data from Tables Clump
Problem connected with the NAND chip - it can't be cleaned.
That's why need to use conpatible donor PCB.
Postby Amarbir[CDR-Labs] » 25.02.18, 08:52
Well,
I can now solve issue of 75% of the cases without any F/W Manipulation .Its interesting how this NAND can be bypassed and Platter can be accessed
lcoughey
Postby lcoughey » 26.02.18, 15:59
Amarbir[CDR-Labs] wrote:Source of the post Well,
Of course you do, I posted how to do it on this forum and my forum a year ago.
Nick_TS
Postby Nick_TS » 27.02.18, 19:26
Dear Jojo,
jojo2012 wrote:Source of the post As you can see the FW is DEMC and if it's possible I can attach the original ROM and the patched one
I don't think that ROM is patched correctly.
Could you past here the log when patch the original ROM.
jojo2012
Postby jojo2012 » 01.03.18, 18:32
Dmitriy_TS wrote:Source of the post Dear Jojo,
Hello Dmitriy,
sadly the customer could no longer wait, and I no longer had PCBs, so I had to close the case differently (outsourcing).
I hope to have another drive in hand to do some testing.
Thanks anyway
Jojo
jojo2012
Postby jojo2012 » 01.03.18, 18:46
lcoughey wrote:Source of the post
Hi Luke,
can you indicate the link please?
Thanks so much
Jojo
lcoughey
Postby lcoughey » 01.03.18, 18:53
Ace is going to get annoyed with my continually linking to this thread on my forum - https://www.recoveryforce.com/forums/vi ... f=12&t=273
Postby Amarbir[CDR-Labs] » 03.03.18, 06:01
Well,
i remembered to have seen this post of your luke ,this time wasim zaffar explained me the same and voila i remembered i had seen it before ,in my case this is the first case i got
