Rosewood Issue Again
lcoughey
Re: Rosewood Issue Again
Postby lcoughey » 17.11.17, 19:43
Usually, with Seagate, if you see the error above and the drive spins down, it is either an issue with the heads and/or the surface. If you have already ruled out heads, I think it is safe to say that the surface is likely damaged and the odds of success are quite low.
