Samsung 256GB MLC SSD MMD0E56G5MXP-0VB
lcoughey
Postby lcoughey » 02.11.17, 15:49
The SSD powers on and gets stuck at BSY. Comes ready with kernel mode shorting, but fails on Loader uploading process.
Trying with the MLC loader:
Selected family......................... : Samsung MLC SSD
Controller.............................. : S3C29RBB01-YK40
Model................................... : Passport not loaded
SSD status:
SSD is in ready state................... : No
SSD is locked........................... : Unknown
SSD is in Safe Mode..................... : Unknown
Loader uploaded......................... : Unknown
Loader uploading
Code name............................... : MLC.ldr
Power Off
Power On
Safe mode............................... : Ok
Write HDD microcode
Waiting 2 sec.
Write Initialization Firmware........... : Ok
Write HDD microcode
Waiting 2 sec.
FW loading error; HDD Start error
SSD status:
Operation aborted
Loader is not uploaded! Some of the functions are not available!
Trying with the MLCR loader:
SSD status:
Loader uploaded......................... : No
Loader uploading
Code name............................... : MLCR.ldr
Write HDD microcode
Waiting 2 sec.
Write HDD microcode
Waiting 2 sec.
Write Main Firmware..................... : Ok
Device error detected "ABR"
SSD status:
Operation aborted
Any suggestions on how to proceed from here?
Re: Samsung 256GB MLC SSD MMD0E56G5MXP-0VB
Postby Roman_TS » 03.11.17, 08:15
Hello Luke. Most likely that this drive contain different or modified firmware which is not compatible with loaders in PC-3000 SSD Database. Anyway, I recommend you to download resources from updatebox for your Samsung MLC SSD. Then - in Utility, try to rewrite firmware using resources from database. It might help. Just be careful with "FORMAT" checkbox - don't use it! Otherwise you will erase the user data on drive.
Return to “MLC SSD Series”
