SA region address can not be shifted back
Imnew
Postby Imnew » 14.10.17, 09:46
I have a WD 2 TB model WD 20 NMVW.
I had shifted the region.
Now can not go back. Whenever I a doing allow SA region, still it shows region shifted.
Can someone help how to have the region address.
ROM version............................. : 21.3RH
ROM generation.......................... : 21.3RH
Link table version...................... : N0.41.
Consolidated ROM version................ : 0021003R
ROM Modules:
Modules directory address............... : 318 128
SA defects assigned..................... : 1
ROM Firmware version.................... : 0021003R
msurgeon
Re: SA region address can not be shifted back
Postby msurgeon » 17.10.17, 20:48
Can't you write back the original ROM?
asocla
Postby asocla » 19.10.17, 02:12
Are you running the shift in Ram or in Rom?
For me you are working in Ram, and you must shift the regions in Rom
Maxim_TS
Postby Maxim_TS » 19.10.17, 13:29
Imnew, go to Work with ROM->Allow SA access and restart HDD menu.
Postby Amarbir[CDR-Labs] » 19.10.17, 18:18
Imnew wrote:Source of the post I have a WD 2 TB model WD 20 NMVW.
ROM Modules:
Well,
The Basic Strategy I Use For Backup Is As Following ,I Enter The Utility In Kernel Mode And Read Rom And Rom Modules Then i Quit Utility Enter Inside Utility again And Read Modules In ABA Mode of Different Heads And Make New Profile ,Like This i Have Two Profiles Of One Drive With ROM And Rom Modules in One And ABA Accessed Modules In Second One .Like This i Have Entire SA With Me And Can Undo Anything .In Your Case You Should Undo This Process By Writing Back Initial Saved Rom Or Using What Maxim Tells You [ though There Are Two Methods To Undo This In Tool ] . BTW Acelab TS Guys The Earlier Version Had " Shifted " Written in Red and It Was So Easy To See this Can You Ask Developers To Change Colour If Shifted To Red In The Very Next Update You Fellows Make .
Maxim_TS
Postby Maxim_TS » 27.10.17, 18:00
Amarbir[CDR-Labs] wrote:Source of the post BTW Acelab TS Guys The Earlier Version Had " Shifted " Written in Red and It Was So Easy To See this Can You Ask Developers To Change Colour If Shifted
It will be marked red in next 6.4 version :)
Postby Amarbir[CDR-Labs] » 27.10.17, 19:02
Maxim,
i would say that good features of one version should be retained in all further versions like this colour thing cheers mate
